Old 01-20-2013, 05:51 AM   #1606
Bill K's Avatar
Originally Posted by 12scale View Post
Try RC Market or Mushroom.
Bought some leespeed spur gears from RAB hobbies. Went down and had a talk to Steve the other day. He recommended some essential hopups and setup tips
Bill K is offline   Reply With Quote
Old 01-20-2013, 01:28 PM   #1607
NolanP's Avatar
BD7 is on the auction block with all my spares contact me if interested.
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Wheeler and Mod Buggy
NolanP is offline   Reply With Quote
Old 01-20-2013, 04:57 PM   #1608
Hugh Jazz's Avatar
Originally Posted by Bill K View Post
Nah man, they only have the thicker kimbourough ones. No use to me
I am using the RW spurs at the moment. Got them for nbhc.com.au. All you have to do is file down the button head screws a bit so it still fits In the bulkheads
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-20-2013, 07:26 PM   #1609
NolanP's Avatar
So how many are running Volkers setup to a t?
What are you finding? Loose or tight etc?
Mod Touring Car
Mod 12th
Nitro TC
Nitro GT
Old 01-20-2013, 08:32 PM   #1610
Bill K's Avatar
I'd much prefer a nice smooth fit, rather than have to edit something and potentially screw up something else... If you know what I mean
Old 01-21-2013, 04:49 PM   #1611
Cadman1981's Avatar
I am using Kimbrough because that's what my local track keeps stock. Took me all of a few seconds to file down the screws so they fit.
Another option, you can use
Tamiya 51211 - RC 3x5 Flat Screws
I hate having to special order a spur gear, especially how easily it can strip.
Cadman1981 is offline   Reply With Quote
Old 01-21-2013, 06:41 PM   #1612
Cadman1981's Avatar
So back to the DCJs... The Yokomos pin is too short, the Tamiyas rub against the hub, the Spec-Rs take a pin that is 2.0mm instead of the Yok's 2.1mm, so what else is there?
Can the pin for the Yokomos be slotted? or is there a longer pin we can use? any ideas?
The track i race on is a tight carpet track, so i will have binding in my CVDs.
Old 01-21-2013, 08:41 PM   #1613
5tylez's Avatar
Originally Posted by Cadman1981 View Post
So back to the DCJs... The Yokomos pin is too short, the Tamiyas rub against the hub, the Spec-Rs take a pin that is 2.0mm instead of the Yok's 2.0mm, so what else is there?
use Tamiya carbon steering knuckles with Tamiya DCJs, and your golden.
5tylez is offline   Reply With Quote
Old 01-21-2013, 10:21 PM   #1614
Bill K's Avatar
Did a hot lap with my BD7 today. Will be uploading to YouTube soon!
Old 01-21-2013, 11:09 PM   #1615
RW spurs with AE 5mm button screw from TC6 works fine
zzztech is offline   Reply With Quote
Old 01-21-2013, 11:40 PM   #1616
Bill K's Avatar
Oh... this is not good! haha.
At the end of my recorded run I left the car on the track to cool down for a bit. When I pick up the car, everything suddenly stops..
Turns out the bullet plugs melted off the solder joint - and solder melts at 180 degrees
Motor came off at 110 degrees while the speedy topped at 50. I wont be running this motor again. Just have to wait for my 13.5 to arrive in the post
Old 01-22-2013, 12:05 AM   #1617
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I ran it for a bit with the exception of the shock bladders because I didn't have those.
I'm running on a smaller carpet track with sorex 32 and sweep 32 and found the set up easy to drive for mod but could use a lot more steering and almost perfect for 13.5 no boost. I only had to change the droop values for less droop and it was almost perfect.
Racing4Evo is offline   Reply With Quote
Old 01-22-2013, 12:08 AM   #1618
Racing4Evo's Avatar
Heat shrink the outside or use shoe goo adhesive? I'll let you know how they fare in a week or so when I get mine from eBay.
Old 01-22-2013, 12:09 AM   #1619
Racing4Evo's Avatar
I want to try this but doesn't this mess with the Ackerman?
Old 01-22-2013, 01:07 AM   #1620
caltek1's Avatar
Trader Rating: 33 (100%+)
I have never had a binding issue with Tamiya DCJ's in my BD7. I have not modified anything and no binding. Mine have been in the car for three or four months.
caltek1 is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
SEO by vBSEO 3.5.0
