Old 01-18-2013, 11:39 PM   #1591
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
17.5 no timing: 4.0
13.5 no timing: 4.5
I hardly change my gear ratio from the above at the local track. Its a smaller carpet track.
Racing4Evo is offline   Reply With Quote
Old 01-18-2013, 11:50 PM   #1592
Racing4Evo's Avatar
[QUOTE=Bill K;11692845]
Originally Posted by cyclonetog View Post
A DCJ has 2 joints, a UJ/CV has one, it's easy to spot.
And how does his provide extra performance? I've never even heard of these before
Bottom line, they make any car easier to drive. When I first tried dcj's I felt like I lost some steering but thats just beacuse the front driveshafts arent causing a drag brake effect from all the chatter at full steering lock. Its an easy setup change to add more steering. You end up being way more consistent on your lap time spread when you have an easier car to drive even though you might not be faster on your flying single lap.
Old 01-19-2013, 12:03 AM   #1593
Bill K's Avatar
I'll be running a 13.5 motor with an 81T spur gear. What pinion would you recommend? I was thinking 27-33 from past experience, maybe 25 or 26 still
Bill K is offline   Reply With Quote
Old 01-19-2013, 12:28 AM   #1594
Racing4Evo's Avatar
Will that mesh right? Ive never tried a spur that small on any car so I can't say. Right now im using the panaracer 96t spur. On my tamiya I usually run a 104 spur.
Old 01-19-2013, 01:02 AM   #1595
Bill K's Avatar
Well I've never really used anything above a 90T spur... Right now I'm racing my Sakura S zero with a 81T spur and 26T pinion with 9T Ezrun combo. Nice speed and winning races. Thats all thats counts
Old 01-19-2013, 07:09 AM   #1596
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
blinky or boosted
blinky you look around 4.5
boosted 6.6 to 8 depending on track
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-19-2013, 09:52 PM   #1597
does anybody knows what is the lb rate for the spring pink and blue yokomo?
f1o7x9 is offline   Reply With Quote
Old 01-19-2013, 10:13 PM   #1598
double post
zzztech is offline   Reply With Quote
Old 01-19-2013, 10:13 PM   #1599
This spring chart has everything
http://www.petitrc.com/reglages/1-10...ingChartv2.pdf
Old 01-19-2013, 11:21 PM   #1600
Bill K's Avatar
Does anyone know if my Schumacher 89T spur gear will fit in replacement for the standard kit spur gear the car comes with?
Here's what it looks like
Old 01-20-2013, 12:54 AM   #1601
Bill K's Avatar
Originally Posted by Craig W View Post
blinky or boosted
Im not sure about Blinky, as I might be running a small amount of timing on the engine.
Old 01-20-2013, 12:54 AM   #1602
Originally Posted by zzztech View Post
Thank you
Old 01-20-2013, 05:16 AM   #1603
12scale's Avatar
Here's what it looks likerom
No it won't different bearing size, order some panaracer spurs, maybe HH has some.
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 01-20-2013, 05:18 AM   #1604
Bill K's Avatar
Nah man, they only have the thicker kimbourough ones. No use to me
Old 01-20-2013, 05:31 AM   #1605
12scale's Avatar
Try RC Market or Mushroom.
Stuart McMillan
Xray T4 2015
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
