Old 01-05-2013, 09:30 AM   #1486
Johnny I'm convinced that the parts in Tamiya 53574 are identical!
cyclonetog is offline   Reply With Quote
Old 01-05-2013, 09:32 AM   #1487
Cadman1981's Avatar
Originally Posted by Johnny Than View Post
anyone has an extra set of these that they are willing to sell?. it's sold out at Amain. I'm willing to pay a little more than retail plus shipping. Thanks in advance.
http://www.amainhobbies.com/product_...r-White-4-Thin
I got mine from ebay, should be getting them next week.
For the shocks being stiffer, did you put the same piston size and oil? the TRFs i THINK have a smaller can, so it could explain why it's stiffer, drop down one size oil weight.
Ran the car yesterday, if it wasn't for my ESC having problems, i would have been able to run it a lot longer, as it is, i barely used 1 pack, with help from a regular, we were able to get the car pretty dialed. We played with the roll center in the front, extended the front top arms to the inner hole, and raised it by 1mm, it actually help keep the front more planted as well. The car is great out of the box.
Is there anywhere i can read about how to setup the car? Not the basics, more the details in Roll Center changes, kick up, caster, etc
Cadman1981 is offline   Reply With Quote
Old 01-05-2013, 10:33 AM   #1488
I've used the equivalent piston, the Yok ones are much thicker so don't fit the shaft anyway.
The o-rings were quite old so I've changed them and the car feels much more normal now, can't wait to try it tomorrow.
Those changes are covered in the XXXMain setup guide.
Old 01-05-2013, 11:00 AM   #1489
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I need a lot more steering. The car is way too stable. What can I do to get the front to react quicker and also get more rotation in the middle of the corner?
Racing4Evo is offline   Reply With Quote
Old 01-05-2013, 11:11 AM   #1490
Mr. MR4's Avatar
Narrow front hubs (4.5mm)
front inboard toe
lay down front shocks one hole
softer front spring
more rear droop
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 01-05-2013, 02:59 PM   #1491
syndr0me's Avatar
Trader Rating: 32 (100%+)
44.2 FF / 43.5 FR
syndr0me is offline   Reply With Quote
Old 01-05-2013, 04:16 PM   #1492
Mr. MR4's Avatar
Originally Posted by syndr0me View Post
44.2 FF / 43.5 FR
You could also use 4degree caster blocks.
Old 01-05-2013, 04:27 PM   #1493
Racing4Evo's Avatar
Yeah thanks guys. I just received the 44.2 block in the mail today. I ran the stock setup and ended up running blue springs front and rear.
Also lowered the front shocks and less rear toe but its still too stuck. The graphite arms helped a little with the sharpness but the issue is more fundamental than that.
Where can i get 4 deg. C hubs?
In the setup sheets on petit rc, they list the droop as distance from ground to what? The bottom of the arm or the hingpin ?
Old 01-05-2013, 04:32 PM   #1494
There is a space for both measurements on the setup sheet.
If you look just above where the measurement is given it'll say "Arm" or "Pin".
Old 01-05-2013, 05:42 PM   #1495
Cadman1981's Avatar
You can also move your roll center, i lengthened my top links, and moved the ball to the inner hole, it gave me more aggressive steering in a turn.
Old 01-05-2013, 06:59 PM   #1496
Johnny Than's Avatar
Trader Rating: 91 (100%+)
umm....does everyone agree with this? not saying that you are wrong... but from my previous testing it always seems to me like shorter camber links make the car more responsive. hence, more initial steering.
Johnny Than is offline   Reply With Quote
Old 01-05-2013, 07:04 PM   #1497
I believe yes, shorter links react faster.
HawaiiBob is offline   Reply With Quote
Old 01-06-2013, 12:08 AM   #1498
From testing other cars, I would agree with both of the things you've said.
Running shorter links all round makes the car react faster, but runnin the front longer than the rear gives more steering.
I haven't tried it on the BD7 yet, but I'd expect the same to happen.
Old 01-06-2013, 01:40 AM   #1499
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
What ackerman are you running? Try 1.5mm. Also try a heavier rear gear diff and 2.5d rear toe. The car comes with 4d C-hubs, 6d wont help your issue.
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 01-06-2013, 02:58 AM   #1500
Hugh Jazz's Avatar
Does this mean a move back to the righgt colour blue for you.
Dan Maher
Hugh Jazz is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
