Old 03-03-2005, 04:34 AM   #1
Default TC3 Oval Setup
I performed a search and could not find any answers. I plan to run a small concrete oval this spring. It has 50' straights and a 9 degree banking. Does anyone have a starting place on the chassis/shock setup?
pcmlc is offline   Reply With Quote
Old 03-24-2005, 01:33 PM   #2
Aries326's Avatar
Trader Rating: 19 (100%+)
Do a search on google for "TC3 setup." I may have pulled it from the teamassociated website but I found a bunch of setups that I printed out.
Aries326 is offline   Reply With Quote
Old 03-24-2005, 05:28 PM   #3
ASM's Avatar
Trader Rating: 14 (100%+)
Need a modified chassis that was the Snowbirds TC Oval winner in 2003? LMK
I'd offer more set-up help but my experience is all on carpet with TC Oval. All I can say is put some gear on it! It's much more than you'd think and go to 64p gears using a 88 tooth from Kimbrough for a spur. Gearing these cars is crucial and it'll keep you ahead of the pack. Many racers assume their on-road gearing is close but it's not anywhere near close!
Do not over engineer the chassis with all types wierd spring set-ups. Start with your basic on-road set-up for springs and go from there. Don't automatically assume the car will work using stiffer right side springs.
Good luck and enjoy!!
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
B4 oval setup help azgreg Oval, Larger Scales and More 6 08-29-2013 02:49 PM
ntc3 oval setup joeyb19 Nitro On-Road 22 06-09-2008 12:06 PM
tc4 dirt oval setup need help please keithw11 Oval, Larger Scales and More 2 01-24-2006 01:21 PM
best oval setup for tc3 erock87 Oval, Larger Scales and More 0 10-20-2004 04:55 PM
TC3 oval setup? help? Elcfreak Oval, Larger Scales and More 9 08-16-2004 01:27 PM
SEO by vBSEO 3.5.0
