Like Tree4Likes
Old 10-18-2012, 06:02 AM   #61
Velocitygt's Avatar
Anyone have them yet and can provide some feedback?
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 10-18-2012, 06:57 AM   #62
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
bought them at first ETS race last weekend and will test them next weekend.
Yokomo BD7 -- Hobbywing v3 -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 10-19-2012, 04:54 AM   #63
Andreas_Myrberg's Avatar
Send a message via ICQ to Andreas_Myrberg
Originally Posted by PitNamedGordie View Post
Thanks! I missed that.
Now the question is do I want to pay $130 USD plus $30 USD shipping for these shocks!?
I am working on getting US direct backing asap so you can at least save on the shipping but it will probably take a month or so until I have something setup correctly.
ETS release was great, everyone where very happy with performance, building and the looks.
Cheers
AME - IRIS - T-Shox - ORCA
Andreas_Myrberg is offline   Reply With Quote
Old 10-19-2012, 04:55 AM   #64
Thanks for the purchase
ETS was a great event, truly impressive event.
Please post your thought here or if you have any questions on anything dont hesitate to post it and I will answer you ASAP
/Andreas
Old 11-05-2012, 06:02 AM   #65
Geberit's Avatar
Hey Andreas,
what comes in the shocks kit? What would you recommend for carpet racing, should I buy some parts separately?
Geberit is offline   Reply With Quote
Old 11-19-2012, 06:29 AM   #66
testing. so far the new tshox made a very good first impression. car feels a little smoother to drive and less edgy still providing the same front and back end grip. all in all a little easier to drive i think and definitely worth a try.testing was down on very high grip carpet (3x1.1 mm, 450oil, yokomo springs blue&pink, 0 rebound, motor 4.5T).
in the next test i will try out different rebound springs. any recommendations for very high grip carpet track?
cheers
werner
Old 11-19-2012, 09:05 AM   #67
Geberit's Avatar
This Saturday I tested the t-shox on my serpent s411te.
First I had to add some shims on the A arm mount to get them straight since the upper mount moves them to an angle. This restricted the front steering because the inner edge of the rim touched the shock mount. The shocks work really consistent and the car was way more easy to drive then wits the standard RCM shocks. I used the short hard rebound spring, 425 cst oil and the yellow AME springs. The combo is awesome on a high grip carpet!
One remark, they leaked slightly on both ends. Maybe got to find some better O-rings ...
Old 11-30-2012, 02:33 PM   #68
Hi Andreas.
I have ordered your T-Shox, a week ago, but received nothing so farr.
How long will it take before I have them at home.
Ed IJzerman
eded1 is offline   Reply With Quote
Old 12-01-2012, 01:31 PM   #69
Spillertwo's Avatar
Do the tshox springs have a lbs rating? Or do you know how they compare to yokomo springs?
Spillertwo is offline   Reply With Quote
Old 12-05-2012, 03:14 PM   #70
Originally Posted by eded1 View Post
Hi Andreas.
Ed IJzerman
I,ve received them yesterday and put them togheter the same evening.
It is a great product and a great example of enginering.
Thanks and I let you know if it works and how.
Old 12-09-2012, 05:23 AM   #71
I,ve run them, started with MM250 oil in it and it feel already good, after 2 or 3 runs changed from MM250 to MM450 and made the same laptimes as before, but by far much ease, and the feeling left over there is more in it.
So far no trouble or leakage except the lost of oil due to comress the oil while mounting.
Old 12-19-2012, 11:09 AM   #72
erchn's Avatar
Hi,
Is there a US or Canadian distributor for AME products? I'm trying to avoid paying $35 shipping.
Thanks,
Ethan
erchn is offline   Reply With Quote
Old 12-20-2012, 07:15 AM   #73
Spillertwo's Avatar
Where is the instruction video for assembly on the website that is mentionned in the manual that comes with the shocks ?
Would also be a very good idea to do the packaging of the rebound springs in seperate packages because now it is a search to find the difference between short soft/hard and long soft/hard springs. I think i have the long soft rebound springs now in the shocks but i am not 100% sure :-)
Old 12-20-2012, 09:23 AM   #74
Quantra's Avatar
Kentech has made a nice review of the TSHOX on his blog: http://kentech.blogs.se/2012/12/17/a...shox-15328316/
The rebound springs can be identified by the number of coils on each spring. More coils = softer spring. I now use a small pill box to keep the springs and other TSHOX spares organised.
Been using mine for a couple of months now and they are fantastic, no leaking just reliable, smooth and consistent. I run med-high grip carpet 1.2mm 3 hole pistons, long soft rebound springs MM#500.
Vince Coleman
Quantra is offline   Reply With Quote
Old 12-20-2012, 09:49 AM   #75
Send a message via AIM to HenBeav
How do these work on a t4 with the shorter shocks. Also can the bigger t4 springs be used with these?
[URL]http://www.fastlanehobby.com[/URL]
Support your local Lowe's, Walmart and Layne Machine Works INC.
HenBeav is offline   Reply With Quote
