AME T SHOX
#391
I did tested today and I'm finding that the green front and rear spring were alittle to soft or the car rolled a little much for my taste..I didn't use the hard rebound spring ..will the reb. spring help or make the differance ?
Hole 3 X 1.3 with the 600wt
PS I had to moved the shock one hole upright in the rear to stop the rolling ..
#393
Thinking of trying them on my BD5, has anyone good experince with the T-shox on this car ?
And what type of oil and rebound spring shall I start out with.
I run only carpet and 17.5 blinky.
Thanks.
Thanks.
#394
I'm sorry, but I'm now waiting for month, is it really a way for me to have my defective shock body replaced?
I've posted here, contacted Andreas, re-posted here, provided all the information...
I'm starting to be really disappointed...
#395
Anyone with experince with the T-Shox on a BD5wxi ??
#398
Trader Rating: 22 (100%+)
Any new news on the T Shox? Any updates on improvements, testing or whatever?
#399
hello, I have assembled these dampers and the materials are very good, but I have a little problem, the blue-rings rubber going down, when I squeeze it stays bastago braking and does not work well, neither rises nor falls well.
-ring rubber seal that use or have to put it?
thanks and regards
thanks and regards
#400
hi guys
well after reading all the post...
i have decide to buy it...and hoping that all the part are in the box and their won't be any problem on building it...
i purchased from rc market since its the close to indonesia...
i have seen the shock work on titc where nick won the race....
anyway... hope it wotk great...
thanks
thanks
#401
hi guys, I solved the problem, now it works very very very good and very very soft as cushions, as it should be, working fine fine.
I replaced the blue by the boards together kyosho. cushions works great, I have to try on track, and I say something.
Blue boards changed, problem solved.
wear long dock in and doing very well. hpi and silver, which I have yet to try the outdoor yellow asphalt
a greeting
a greeting
#402
Hi Craig
#403
hello, I've tried the t-shox. I've removed them azul10041 board up and down. I've put kysoho board and it works fine, the problem is that you lose a little oil over the bastago, I have to look for a better seal see what happens to oil leaking.
the problem I have is that in my car, took tshox raceberry and the remains of the car alanate high 7de 6.5 and up and that is very high.
some that have the same and have fixed?
a greeting
a greeting
#405
a greeting
a greeting
