Like Tree5Likes
Old 03-23-2013, 09:48 PM   #361
Smile
Originally Posted by Airwave View Post
Hi guys!
I just finish mine!
Quite complicated to assemble with only this small piece of paper... So after the first one, I look for the Vimeo page and everything was better...
By the way, I find the quality a little bit approximative, as I have defaults on the anodization... but I can live with that...
The other point bothering me is that it seems that I have a shock shorter than the others...
The shaft seems not to go as low as the others...
Is there any feedback about a similar problem?
From what can this problem come?
Thanks in advance.
What shock stand is that, looks the ticket
B.C.Ninja is offline   Reply With Quote
Old 03-25-2013, 12:43 AM   #362
defcone's Avatar
Trader Rating: 15 (100%+)
yeah my ones were unscrewing and oil was pissing everywhere
defcone is offline   Reply With Quote
Old 04-02-2013, 08:43 AM   #363
Some of you may know and some won't, but the team have been having some strong results using pistons with 3x1.4mm holes and oil in the 500 to 600 range on Tshox Short and on carpet or asphalt. Be safe to test.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 04-18-2013, 04:56 PM   #364
Penz316's Avatar
Hello,
I ran the T-Shox for the first time at my track last week-end. I'm not sure of my setup but on a 6 minutes heat, the car was more consistant with the T-Shox.
I'm wondering what oil people are running on carpet ... very short track with banking (it's a oval track with on-road inside)
I'm running 17.5T Bling with a Xray T4
Alex Fournier
Team Associated | Reedy | Team Scream Racing | Hyper Hobbies
Penz316 is offline   Reply With Quote
Old 04-18-2013, 06:02 PM   #365
BadPanda818's Avatar
Trader Rating: 17 (100%+)
Really interested with the product. Would there be shock shaft long enough for my TA06 with the lay down suspension? I have a feeling this would be key specially with our 120 degree track during the summer. Thanks
Capricorn Lab TE-01 Orion R10 Pro, Orion VST2X 17.5, KO RSX One
Capricorn Lab TE-03 Orion R10.1, Fantom Ion V5, KO RSX One
Xray XB4 2017, Orion R10.1, Fantom FR-1 13.5, Protek 160T
Axial RR10 Bomber, MMP, Reline Pro4 4000Kv,Protek 150T
Futaba 4PKS R All sponsored by Visa
BadPanda818 is offline   Reply With Quote
Old 04-22-2013, 08:20 AM   #366
Andreas_Myrberg's Avatar
Send a message via ICQ to Andreas_Myrberg
Originally Posted by Penz316 View Post
Hello,
Hi,
At the moment we are running 3x1.4mm holes in the pistons with 550 oil.
Sometimes we run 50 lower weight front to make it easier to drive.
This is also the setup we ran when we took 1:st and 2:nd at the German Nats the other week.
Cheers
AME - IRIS - T-Shox - ORCA
Andreas_Myrberg is offline   Reply With Quote
Old 04-22-2013, 08:22 AM   #367
How long does the shock and the shaft need to be to fit the TA06?
I have no experience with this specific Tamiya.
In all the other Tamiyas, the T-Shox fits perfectly and we took a great result at the TITC in open stock class with TQ and victory with a Tamiya mounted with T-Shox.
please let me know about the size, thanks
/Andreas
Old 04-22-2013, 12:23 PM   #368
/Andreas
The lay down shock shafts are 49.6mm long. thanks for looking into it
Old 04-22-2013, 12:42 PM   #369
Penz316's Avatar
Thanks Andreas, this is pretty much what I got in the shock.
What rebound spring do you use ?
For me, T-Shox was not faster on one lap but much more consistant during the entire heat. The car feel better and is a little more predictable. Great product !
Alex Fournier
Old 04-22-2013, 04:54 PM   #370
Penz316's Avatar
My T4 with T-Shox
Alex Fournier
Old 04-29-2013, 04:30 AM   #371
dMITIj's Avatar
So how do you guys like the T-Shox? is it worth the $$$$ ore?
TLR 22-4.
ORION VORTEX R10.1 Pro ESC.
ORION VORTEX VST2 PRO 7.5T.
ORION CARBON PRO 4500 100C 7.4V SHORTY PACK x3.
Sanwa MT4S Radio/RX-481 receiver & Xpert RC PI-3402 Brushless Servo.
dMITIj is offline   Reply With Quote
Old 04-29-2013, 05:41 AM   #372
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
On the Xray T4, how many spacers are people using between the suspension arm and the lower shock eyelet so that the shock is vertical?
dontfeelcold is offline   Reply With Quote
Old 04-29-2013, 07:45 AM   #373
scoyle's Avatar
Planning to go outdoors with my T4 soon... its a medium grip track but just looking for a starting point.
What oil/pistons are people using on tarmac?
Web Site: http://www.rcracingreviews.net
Sponsors: Schumacher UK | XFactoryUK | Zen Racing
scoyle is offline   Reply With Quote
Old 04-29-2013, 07:50 AM   #374
Matthijs's Avatar
1.3x3 with 450 and ame green springs
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 04-29-2013, 10:13 AM   #375
Spillertwo's Avatar
Hi,
Cheers
Hello Andreas,
Is this with the short shox for xray or with the normal shox ? Would you advise this option for use with the Yokomo BD7 ?
Also a question about the asphalt spring set. Somebody told me that for the asphalt springs you have to use the long spring on the front and the short spring on the back. Is this correct ?
Spillertwo is offline   Reply With Quote
