Like Tree5Likes
Old 01-22-2013, 10:41 AM   #166
Nico''s Avatar
Originally Posted by jorgesimes View Post
Front and rear the same, yes.
1,2 drill i found it on Leroy Merlin, same as Walmart i think. Don't know where you are.
Leroy Merlin exists in France yes, thanx a lot.
I leave in the east of France, close to Germany and Switzerland.
Nico' is offline   Reply With Quote
Old 01-22-2013, 06:14 PM   #167
bozzplayer's Avatar
Trader Rating: 16 (100%+)
any good starting points for these shocks for the yokomo bd7, i run on medium grip carpet in 17.5 blinky, also can i use my yokomo springs or do i need the t-shox ones. Thanks for any help
bozzplayer is offline   Reply With Quote
Old 01-22-2013, 09:34 PM   #168
Nico''s Avatar
I think you can use the xray ones, but not tested yet.
You have a starting point from the Team in Germany:
std piston drilled up to 1.2mm (31,2mm piston)
MR33 500wt shock oil
Rebound spring Short/Hard
T-Springs
Front and Rear Yellow (Carpet Medium)
Hope this helps.
Hi,
500wt oil seems to me to be thick for usual settings with standard T4 shocks, does it mean that T shox needs to be used with thicker oil than standard T4 shocks please?
Do you know about MR33 500WT is wiht Muchmore oil please?
thanx,
Nico'
Old 01-22-2013, 09:40 PM   #169
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
would start with 1.1mm pistons short hard rebound spring with 500 oil and pink and blue or t spring yellows
Orca www.ChubbiesCarShack.co.uk TDX SMC RC Airbrush Fundecal
Craig W is offline   Reply With Quote
Old 01-23-2013, 03:13 AM   #170
Originally Posted by Nico' View Post
Hi,
thanx,
Nico'
There is some much math calculation on your question that i'm not the perfect person to answer you. Nothing better than testing 1o1, i will try to do that once the storm around passes, wich will be next week.
About the oil i think, but not 100% sure, that MM oil is a little thicker than MR33, but like i said not sure right now because i remember talking with Toni about that but it was a long time ago, i always try to use the same brand of oil and not to be worried about that, testing is the best and get your thoughts.
Cheers,
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 01-23-2013, 07:34 AM   #171
syndr0me's Avatar
Trader Rating: 32 (100%+)
AME's web shop is charging double the price of RCMarket FYI.
syndr0me is offline   Reply With Quote
Old 01-23-2013, 09:53 AM   #172
theatriks's Avatar
just got the shocks ....build was fairly easily ....followed the video ...to me the video is the exact same as the instructions......the only complaint for me is i wish the rebound springs were colour coded....having a little trouble figuring out which is which...
theatriks is offline   Reply With Quote
Old 01-23-2013, 11:34 AM   #173
spencehotbodies's Avatar
Hello
I had the same problem with the springs, the best way is to put all the same length together.
And the finger test.
spencehotbodies is offline   Reply With Quote
Old 01-23-2013, 11:40 AM   #174
theatriks's Avatar
Originally Posted by spencehotbodies View Post
Hello
Thanks....i kinda tried that ...but i will double check tonight....i thought i put 4 of the short hard springs in but my rebound is different so i will double check tonight
Old 01-23-2013, 08:20 PM   #175
Craig W's Avatar
hi guys got 2 t4 carpet sets and 1 tarmac t springs in
they also fit the new serpent shocks as well
www.chubbiecarshack.co.uk
Old 01-23-2013, 11:04 PM   #176
Matthijs's Avatar
if you put them all on the table you will see the difference, the hard short ones have less windings than the other short ones.
On our tight indoor track with dots in the corners I've removed the rebound springs. I build my 'normal' shocks without rebound and tested the T-shox with the short hard rebound springs. Car flipped very easy after hitting a dot. After removing the short springs my laptimes and car handling returned to (slightly better than) normal
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 01-24-2013, 06:29 AM   #177
Velocitygt's Avatar
For Sale!
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 01-24-2013, 06:53 AM   #178
theatriks's Avatar
thanks matthjis but i ran into another problem last night i noticed one of my shock caps is defective....Andreas said he will replace it for me....so now its some more waiting before i get to test.
Old 01-24-2013, 09:45 AM   #179
Skiddins's Avatar
Has anyone managed to get the T-Shox springs into a machine to test their rates?
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-25-2013, 10:10 AM   #180
wtcc's Avatar
I received my short Tshox this week and really love how smooth they are. I found the short hard rebound springs and even shorter springs in the package. Do the short Tshox need shorter rebound springs?
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
