Like Tree2Likes
Old 01-22-2013, 12:55 AM   #151
Matthijs's Avatar
Originally Posted by jorgesimes View Post
I can guarantee you both that is like this.
did you ask andreas?
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 01-22-2013, 02:17 AM   #152
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
I did, and the video posted here is correct. The large delrin spacer, small oring, and conical spacer sit loose on the shock shaft whilst you screw down the shock cap with large oring (installed in the shock cap).
Hope this helps. An official video will be posted soon.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-22-2013, 02:30 AM   #153
Matthijs's Avatar
ok, will try this tonight. It's about time there is an official video or some clear instructions for this otherwise great product ;-)
Old 01-22-2013, 02:51 AM   #154
If he said that this way in the video is correct, then his instructions are wrong!
It clearly show's the small derlin washer sitting into the shock cap, followed by the blue O-ring, larger derlin washer then all held in cap with large clear O ring.
kdempsey is offline   Reply With Quote
Old 01-22-2013, 03:08 AM   #155
spencehotbodies's Avatar
i think the picture in the instructions are the wrong way round, i have built mine, large white cap then blue o-ring then plastic conical spacer which in turn fits in to shock cap.
spencehotbodies is offline   Reply With Quote
Old 01-22-2013, 03:23 AM   #156
Don't misunderstand me, but you are seeing it wrong. That picture is only to show you how the guidance washers sit on the top shock cap, not even the blue oring is there beetween the 2 pieces, is a side cut view of the top body section. If you take a look into phase 2 it as a picture just like that one, but with the bottom body section.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 01-22-2013, 05:23 AM   #157
I see he has now added your video to the AME Facebook page so you are correct, sorry! I think a lot of people may have been building these wrong like myself..
He should update his instructions and also provide official video as promised..
Thanks for your help,
Keith
Old 01-22-2013, 05:35 AM   #158
Keith
When a company or a product is new sometimes issues may arise, but i'm pretty sure Andreas will handle all and will solve them ASAP.
I did this on my own and for sure it is not perfect, in the end i'm just a passionate hobbyist. If this video could help you guys even better, that's why i did it.
Any more questions i will try to answer.
Team AME/ORCA
Old 01-22-2013, 07:49 AM   #159
Matthijs's Avatar
ok, did a little rebuild ;-) both building options result in the same ;-) if you build it like in the video from Jorge it is easier to get rid of the excessive oil in the shock. It is somewhat more difficult to get the cap seated right before you tighten it.
If you build it the other way (following the logical picture of the manual) you are sure to have some excessive oil wich can't get away. This way you can't tighten the cap far enough. After letting the shocks sit a day on the bench the excessive oil has come out (through the o-rings/shaft) and you can tighten the cap some more. This isn't the best way of building a shock, at least not at the track ;-) unless you can find the accurate level of shockoil...
After both builds the shockcap and the internals (seals, o-ring, etc) come off the same way, all internals are seated in the shockcap. So constructionwise it comes down to the same ;-) but offcourse the video is the best option to use.
One more thing, for a perfect seating of the piston on the shaft use a 0,2 or 0,1 shim between the piston and the e-clip. I found a little play on all shafts.
Old 01-22-2013, 08:43 AM   #160
Quantra's Avatar
Rebuilt mine as per the video today as well, it's how I will build them from now on. However when I remove the top caps from mine now the large spacer stays on the shock body and does not stay in the top cap. Just thought I'd note that...
Vince Coleman
Quantra is offline   Reply With Quote
Old 01-22-2013, 08:55 AM   #161
Team EAM
EAMotorsports's Avatar
Trader Rating: 77 (100%+)
Send a message via AIM to EAMotorsports
Default Snowbirds
Anyone in the US looking to check out the Tshox stop by and see me at the Snowbirds. I'll have a few sets you can check out.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID.
EAMotorsports is offline   Reply With Quote
Old 01-22-2013, 08:55 AM   #162
Nico''s Avatar
Hi,
I bought T shox for my T4, with the springs,
Do you have a starting set up for them please for high grip carpet and running LRP CPX?
I use MM oil and the carpet is the same as the Grand Prix des 3 Frontières in Longwy ( France)
can I use X ray T4 springs please or only T shox springs?
thanx,
Nico'
Nico' is offline   Reply With Quote
Old 01-22-2013, 09:00 AM   #163
Originally Posted by Nico' View Post
Hi,
thanx,
Nico'
I think you can use the xray ones, but not tested yet.
You have a starting point from the Team in Germany:
std piston drilled up to 1.2mm (3×1,2mm piston)
MR33 500wt shock oil
Rebound spring – Short/Hard
T-Springs
Front and Rear – Yellow (Carpet Medium)
Hope this helps.
Team AME/ORCA
Old 01-22-2013, 09:28 AM   #164
Nico''s Avatar
T-Springs
Hope this helps.
thanks a lot,
front and rear are the same springs, the shorts one?
if you have a link to find 1,2mm drill please?
Old 01-22-2013, 09:36 AM   #165
thanks a lot,
Front and rear the same, yes.
1,2 drill i found it on Leroy Merlin, same as Walmart i think. Don't know where you are.
Team AME/ORCA
