Old 01-19-2013, 09:07 AM   #136
Skiddins's Avatar
Originally Posted by spencehotbodies View Post
Cool from Toni sport?
Yes, though nothing to do with T-Shox.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-21-2013, 09:11 AM   #137
Default T-Shox Assembly Video
T-Shox Assembly procedure
Hi All,
This is my method and only my responsability, i'm pretty sure AME will bring an instruction video very soon, until, you could watch how i do you it and some more details of the T-Shox.
Extra Tip - Use an arm reamer on the guidance pieces
Somehow missed the part when i put the rebound springs on the shock shaft, you should put it before you fill them with oil.
Hope you like it.
Cheers.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 01-21-2013, 12:18 PM   #138
Matthijs's Avatar
Hi All,
Hope you like it.
Cheers.
isn't part 10040 (large o-ring) supposed to be seated between the shockbody and part 10042? now you've mounted it in a position were there is no o-ring between the shockbody and the plastic shaftguidance (but an o-ring between the shockcap and the guidance)
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
Old 01-21-2013, 12:23 PM   #139
TheCoolCanFanMan's Avatar
Shame the vid cant be open via a monile-cell phone?
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 01-21-2013, 02:53 PM   #140
I think you might seen it wrong, 10040 is supposed to be in the spring tensioner and top shock cap, 10041 is for the top and bottom shock shaft beetwen the 2 guidance shim, just like any regular shocks, except the top. Hope you understand it, my english may not be that good.
Gonna try to solve it. Sorry.
Team AME/ORCA
Old 01-21-2013, 03:36 PM   #141
Skiddins's Avatar
Cell phone!!! get off your arse, walk back to home from work (ha!) and look on a proper computer you lazy sod
Skiddins
Xray X12 2016
Xray X1'16
RCDisco.co.uk
Old 01-21-2013, 04:04 PM   #142
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
I think he meant that the large o ring in the shock cap is used to hold the:
1. Conical spacer
2. Small o ring
3. Large delrin spacer
So the large o ring holds it all in place in the shock cap and it gets screwed down to the shock body. Your video has the all the items sitting free on top of the shock body and the shock cap with large o ring screws down on it all.
Maybe he is asking you if you correctly installed those parts? I do not know him, but that sounds like what he is asking.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-21-2013, 04:54 PM   #143
1. Conical spacer
2. Small o ring
The propose of that oring is not to hold those 3 itens in place. The top guidance, wich as a conical side to the cap, will hold the oring against the large guidance. Same in the bottom set. I think the large oring is just to avoid unwanted unscrewed and also match the joint of the large guidance and the shock body, just my guess. But gonna ask that.
And the large guidance on top of the shock body as a little of splay that will get inside the diameter of the body and will hold the oil inside the shock.
Team AME/ORCA
Old 01-21-2013, 05:08 PM   #144
I think it will not be possible because of the music author rights.
Team AME/ORCA
Old 01-21-2013, 07:46 PM   #145
Default ame tshock
Who is stocking them in the united states?
bigtee is offline   Reply With Quote
Old 01-21-2013, 11:41 PM   #146
Matthijs's Avatar
1. Conical spacer
2. Small o ring
thats what I mean and if you look at the (crappy) manual you will see why.
Old 01-22-2013, 01:25 AM   #147
Looking to the manual, it seems that o-rings goes in after large delrin spacer, and keep it on the shock cap. I have assembled it this way but i'm also waiting for official video
guru83 is offline   Reply With Quote
Old 01-22-2013, 01:25 AM   #148
spencehotbodies's Avatar
hello
very good vid
spencehotbodies is offline   Reply With Quote
Old 01-22-2013, 01:47 AM   #149
I can guarantee you both that is like this.
Team AME/ORCA
Old 01-22-2013, 01:52 AM   #150
ok i will try like you do in the video, thank you
SEO by vBSEO 3.5.0
