Turbo 35 GFX Problem >
Old 02-23-2005, 07:05 PM
Rob Phillips's Avatar
Unhappy Turbo 35 GFX Problem
Has anyone had any problem with there gfx? Mine is froze on one page and won't allow me to do anything. I've tried disconnecting the power and leaving it of for a while and still nothing.
This is what it displays after booting up;
[READY] chg mode
[SETUP]
The buttons still chip when it push them, but nothing happens. This happened after I notice that program seven was displaying some weird font/symbloms/letters or something. I loaded that profile to see what I had saved there and then it happened. It's only about 2 months old. I'm using a River Gate 30 amp power supply. Any info will be greatly appreciated.
Rob Phillips is offline
Old 02-23-2005, 07:14 PM
TeamButter's Avatar
Contact them directly. They have great Tech support over the phone and should the unit need repair, fast turnaround.
Competition Electronics
3469 Precision Dr.
Rockford, IL 61109
815-874-8001
TeamButter is offline
Old 02-23-2005, 07:22 PM
contact competition electronics.
they may be even to help you over the phone. they have excellent customer service. if you have to send it in they have quick turnaround. anything i have sent in to be checked or fixed was done in three days. their labor rate if needed is very reasonable and their work is very honest. they will tell you what went wrong.
baih is offline
TeamButter's Avatar
Wow!! you just repeated everything I said!!! LOL!!!
Old 02-23-2005, 07:26 PM
Thanks for the help guys, I didn't know if it was a common probelem and I could get a quick fix. I guess I give them a call in the morning. I hope it's a simple over the phone fix, but with my luck, it's never a simple thing.
Old 02-23-2005, 07:28 PM
I am almost 100 percent sure you just blew a fuse. Check those and replace if one is burnt.
Chris
mtc3od is offline
Old 02-23-2005, 07:29 PM
Team Butter, btw, I like the paint scheme your running on your TC's. I ve seen some pics, and man I have say Luck's work is awesome. I'm a big fan of his and Roly.
Old 02-23-2005, 07:32 PM
Already checked them and to the eye they looked fine. I will have to get out the old Fluke in the morning and check them. I thought when you blew a fuse it wouldn't work at all. Thats usually the design purpose of fuses.
Old 02-23-2005, 07:34 PM
everytime I had a problem I just replaced the fuses and It worked just fine. My gfx did wierd things like yours is doing when I blew them. Just replace and try
Chris
mtc3od is offline
sometimes a second thought is needed. lol
should i change the springs??
what about different oil ??
maybe new tires ??
i wonder what inserts that guy is running.
its the ride height !!!
lol lol
baih is offline
Old 02-23-2005, 07:35 PM
wierd
mtc3od is offline
Old 02-23-2005, 07:38 PM
TeamButter's Avatar
Rob-Thanks. The Scheme i am running now is Originally from Roly. It's now Luck's version of Roly's design. As you said, both of them are amazing painters.
Good Luck with the GFX.
Old 02-23-2005, 08:10 PM
Thanks.
I tried to post a pic over on the painting forum with no luck. It looks just like the green body with yellow, orange, and white that Roly did.
Old 02-23-2005, 09:19 PM
centax error!'s Avatar
...that's what I thought too and I was wrong . Listen to what everyone is saying here ..... happened to me couple of times and the fuse works like magic
centax error! is offline
Old 02-24-2005, 08:24 AM
I am listening, I said I will have to get out my meter and check the fuses in the morning. Thanks, I'll let you guys know what was wrong.
