Old 09-05-2012, 11:08 PM   #16
racer x 1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by dan22 View Post
Any setup tips for carpet? I'm going to the iic and could use some setup tips. Going to go to TQ Raceway tomorrow night and see hoe it does.
run 1.5 shims under all suspension blocks to start, 6 fr and 5 rr droop, 37.5 oil front and rear with rsd pistons and 16lb fr and 14lb springs, 1mm wheelbase shims, and SOREX tires. that'll get you going.... theres more of course but this is what I remember. Im still tweaking my set up there but its pretty quick.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 09-06-2012, 08:00 PM   #17
rosko's Avatar
are the bellcranks gonna be blue or like in the photo? doesnt matter either way but just wondered
rosko is offline   Reply With Quote
Old 09-07-2012, 06:25 AM   #18
Paul.Spencer's Avatar
Ready to go!!
Mild to Wild RC | DeadStarRC.com |ACE Hobby Australia |
TEAM Associated TC6.1WC |Team Orion | Reedy| Sweep
TEAM Associated 12R5.2 |Team Orion| Reedy| Matrix
TEAM Associated B44.1.5 |Team Orion| Reedy| Sweep
TEAM Associated B8.2eFT |Team Orion | Reedy| Sweep
Paul.Spencer is offline   Reply With Quote
Old 09-07-2012, 07:55 AM   #19
racer x 1's Avatar
Originally Posted by Paul.Spencer View Post
Ready to go!!
nice steering rack! haha where did you get that from?
Matt Bell
Old 09-07-2012, 10:05 AM   #20
Fred Hubbard's Avatar
It's Xray.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 09-07-2012, 01:32 PM   #21
Originally Posted by Fred Hubbard View Post
It's Xray.
Ciao Fred could you pls post more detailed photo?m i'm also interested
Tnks
Max
Touring: WRC STX
F1: WRC F-ONE 200 and 180 mm
ESC:Viper VTX10R; Motor: too many; Radio: Sanwa MT4
Don't follow me.... at the end of the straight there is the hairpin and my wall.....
mtaddei is offline   Reply With Quote
Old 09-07-2012, 01:35 PM   #22
Tnks
Max
Sorry Max, it's not my car. I was just commenting on the steering post and crank.
Old 09-07-2012, 05:02 PM   #23
So.I.wouldnt actually suggest doing this mod. It turns out to be expensive and a little giddily to get right.
It's basically 302506 with modified arms, the EXOTEK zero steering link and two of the exotek steering braces. So all up around 90$ lol. You also have to flip the steering knuckles around add shims and use associated ball ends. So you can do.org but wait for the.EXOTEK release, I will be lol.
Old 09-09-2012, 05:42 AM   #24
Velocitygt's Avatar
My TC6TEK Conversion ready to go.
Tamiya Shocks with Exotek black hardware.
First impressions were great with my standard TC6 setup. More overall grip and a very smooth/balanced easy to drive feel. Very similar to a 417x although seems to generate more mechanical grip. A lot less chassis scrape with the narrower chassis which makes the car more predicatble in sweepers. l will post my base Medium grip asphalt setup soon.
Definetly makes the car a lot easier to work on and looks prettier
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 09-09-2012, 08:59 AM   #25
rosko's Avatar
What holes in the chassis are gonna be used to mount the servo when using the dual bellcrank? I cant really tell from any of the pics
Old 09-09-2012, 09:19 AM   #26
My times improved by a fraction on first run with some tweaking should get faster, I race on medium grip asphalt so will be interested in your setup Velocitygt, the only thing I have done for mine was slightly heavier springs and as I said got faster.
TC6,Futaba,Reedy Sonic 21.5
Blatracer is offline   Reply With Quote
Old 09-09-2012, 05:01 PM   #27
Will the TAMIYA blocks work with this conversion also?? Also is the new dual bell crank steering going to bolt to this chassis or is another chassis going to be released?
Pinionizer is offline   Reply With Quote
Old 09-09-2012, 06:12 PM   #28
Where did you pick up the TAMIYA shocks?? What did you have to do to mount them to the car??
Old 09-09-2012, 08:37 PM   #29
Velocitygt's Avatar
The Tamiya Shocks are from here
And the Black hardware is from here
They fit right on, Just use with TC6 (not TC6.1) shock ball cup bottoms with a 1mm shim before your screw it on. Total shock length 63mm.
The TC6Tek Chassis has holes for both the standard TC6 steering system and the upcoming Exotek one.
Yes Tamiya blocks will work with this car.
Cheers!
Old 09-12-2012, 07:02 PM   #30
Potoczak's Avatar
Trader Rating: 107 (100%+)
Anyone have an idea when the new steering rack will be available from
Exotek??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
SEO by vBSEO 3.5.0
