Alloy gear set for Spec R diff
Hi
Looking for someone that can make a alloy gear set for a Spec R diff, the original gears just don't hold to to racing mod on a track that has good grip and hard braking. I will send a original gear set to any were in the world, just need to find someone that can make them. Regards Gary |
Originally Posted by GSM Storm
(Post 11009918)
Hi
Originally Posted by GP40X
(Post 11010005)
Have you tried the carbon fiber replacement gears?
Regards Gary |
(Post 11009918)
Hi
Looking for someone that can make a alloy gear set for a Spec R diff, the original gears just don't hold to to racing mod on a track that has good grip and hard braking. I will send a original gear set to any were in the world, just need to find someone that can make them. Regards Gary AWD |
i have a 3 gear diffs for my 417... specR, tamiya, and 3racing
specR - nt1 gears wont fit tamiya - nt1 gears wont fit 3racing - nt1 gears fit |
Originally Posted by andrewdoherty
(Post 11010287)
I built several Xray gear diffs before Xray released theirs. I had to modify NT1 diffs and used aftermarket light weight gears and pins, leaving me with extra steel gears. I have a Spec R 38t gear diff on it's way coincidentally. I'll see if the steel gears from the NT1 work in the SpecR. If I don't post, PM me in a week or two and remind me, and I'll tell you what happened...
AWD No the NT1 gears won't fit in the spec R case and the NT1 diff won't fit in the Schumacher :cry: I have a TA05 Tamiya gear diff coming that looks like it may fit, will need to make some new outdrives and change the front spool pulley to Tamiya as well, but would like to get some alloy gears made so I can just use the spec R case that is made for the Schumacher. Regards Gary |
(Post 11010312)
Hi Mate
Originally Posted by VooDooPH
(Post 11010300)
are you using it with putty?
Originally Posted by R1wurks
(Post 11012147)
Regards Gary |
