Old 07-17-2012, 06:18 PM   #1
Send a message via AIM to Carpetracer92
Default Ofna gtp2e 14/51 gearing
Well i just bought the car to bash with. I am running the hpi flux 2200kv motor with a mamba monster v3. So i am wondering what's the best for gearing? Also where can i buy the pinion gears and what not. I can only find 18 for the highest motor pinion.. Please recommend the rite tires and springs.. Thanks.
Check out Long Island Low N Slow
Garage= Slammed g37,Full Exhaust
Carpetracer92 is offline   Reply With Quote
Old 09-30-2012, 10:49 PM   #2
Trader Rating: 16 (100%+)
I see this is a few months old but in case you still want to know:
The largest pinion you can fit with the 51T spur is 26T. I have a bunch of different pinions all the way up to 30T that I bought on amainhobbies.com. They are the Tekno pinions. You will need mod 1 pinions that fit a 5mm shaft. The best gear setupdepends on what you want to do with it and how many cells you are running. I run 6s and if you gear it for about 60MPH the motor won't over heat and you should see descent runtimes.
I think the stock springs are fine and the stock tires are fine for bashing too up to about 65MPH. Much faster than that and you risk a blow out. If you want to go faster you need either belted rubber like Ipanema, GRP ect. or foams. I run John's BSR racing foams and have been very happy with them.
yakfish is offline   Reply With Quote
GT8 Class--buggy-based on road electric! snrscion Electric On-Road 3416 05-05-2016 12:10 PM
Ofna Ultra GTP2e snrscion Electric On-Road 2121 07-15-2015 11:52 AM
SEO by vBSEO 3.5.0
