New LRP Flow Esc
#1368
#1369
here's also the relevant setup sheets - one from Arno (petitrc), one I modified to suit.
#1370
Anyone else have issues getting the Spec 2 USB bridge to work on a Windows 8 system? Mine simply wouldn't recognise that the ESC was connected. Tried a fresh install of the software but to no avail. In the end I went to my old XP based desktop and it worked first time. But it would be better if I could use my laptop..
#1371
Yeah I have seen this as well, Win8 did not load the drivers correctly for the bridge in my situation. I didn't try very hard to resolve the problem as I was in a rush when it happened.
I use either WinXP or Win7 machine to perform upgrades
#1372
#1373
did anyone notice that v4.7 BD3 braking is much stronger than BD3 braking on v5.4 software ? I noticed way stronger braking with v4.7 on R1 17.5 motor. Anyone had the same experience? I feel this should not have been the case. I'm pretty certain the radio calibration is correct on both occasions.
#1374
Yes that's true.
You need brakes in mod/boosted classes - not so much in 13.5/17.5/21.5 classes.
#1376
Dunno. Never tried. I expect not seeing as LRP probably know what they are doing.
When you are comparing the breaking, are the setting on the ESC the same - initial brake and drag brake?
#1377
#1378
Recently sold my buddy a practically brand new LRP Flow ESC. I been helping him put together his B5M. Well today was his big day and when we wired his stuff up we found a broken swithc wire goin to the esc. So i spoke to another buddy and we checked it out.
So we got it apart. i bridged the circuit board joints where the switch wires go. and there was no power.
we then gently pulled th circuit bard out of the casing and soldered the switch in. Stil no power. I dont get it nothing smells burnt or anything wierd just no power??
suggestions??
suggestions??
#1380
R/C Tech Elite Member
suggestions??
suggestions??
i think it is a smart design for the ESC to stay "on" if the switch falls off/gets disconnected.
