Old 08-12-2002, 02:36 AM   #61
If you suspend the wheel above acetone in a closed container, the glue will soften enough to get the tire off, and you will be able to keep the wheel, tire and insert. Just periodically check them, say overnight.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 08-12-2002, 11:43 AM   #62
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Besercoe - interesting idea, I hadn't thought of that. I will give it a try.
Iso - boiling makes the CA stiffer so it will break off. I tried boiling and it worked, but it burned my fingers as I worked the tires off.
If you wanted to keep the tires, I would probably sacrifice the inserts since they are cheaper than the tires are. . .
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 08-12-2002, 06:41 PM   #63
spawn's Avatar
Is there a difference if I run front foam tyres in the rear? are the rear foam tyres any different? also what will happen if I run higher shore in the rear? My back seems to wear faster than my front. I think front has minimal wear but the back wears about 1-2mm per outing (3 to 4 battery packs, 30 - 40 minutes of mod motor)
spawn is offline   Reply With Quote
Old 08-12-2002, 08:57 PM   #64
fatdoggy's Avatar
Did you adjust your ride hight (pre-load) in the rear so that it compensates for the taller foams? If not the rear of the car would have a higher center of gravity in the rear and more roll, that would make the tyres wear since more of the tyre is making contact with the ground.
If that didn't make sence....
There is a camber change when you adjust pre-load, so if the tyres are taller you'd need a pre-load adjustment to compensate and take your camber back to it's original setting.
This is just a guess, I don't have any experience with running higher shore foams in the rear....
fatdoggy is offline   Reply With Quote
1/10 Foam Tyres - Twister Tyres LogiK Australia For Sale/Trade 4 08-13-2008 04:25 PM
AE 12L4, Foam & Rubber Tyres FS Scotty G Australia For Sale/Trade 1 12-16-2007 07:51 PM
Tyres! Foam or Rubber ben_emmo Rookie Zone 5 03-20-2007 06:56 AM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 10:02 AM
HPI rubber tyres new or used penggoy R/C Items: Wanted to Buy 1 05-02-2003 03:51 PM
SEO by vBSEO 3.5.0
