Yokomo MR4TC-BD
#7546
#7552
how do I identified which chassis my bd has when I checked the last page of the user manuals there is a exploded car with all part numbers and it says BD-002G for main chassis part no does it means my car has the BD-002G chassis???If so Is that a bit stiffer than the old old bd chassis???Bd-002???
#7553
hi all, im going to try a spool in my bd 2moro wat do i need to do to make the car more suited to it? im running on a tarmac track .
thanks
thanks
#7554
i bought the selection of tamiya shims to evenly space the diff im not sure how many shims i used but i got alot left over but its worth it no more wear and the out drives last
they came in 1 through to 3mm shims
worth a shot if your sick of replacing out drives and you dont notice the weight much any way
#7555
i see. could u take some pics on ur next rebuild? lay out all the parts in order of assembly? u know what they say about pics.
PS. how do u cure wheel nuts constantly come off during a race, blue lock tite?
#7556
hi all, heading up to stafford indoor this week and its my first time using rp 24 so i am worrying about grip rolling in 19 turn class. i have the 3mm and std chasis and only have rayspeed springs so could anyone please surgest a set up.
any help i would be gratfull of.
thank you
thank you
#7557
is this the part that is needed for the cgm steering mod doesnt look like it. part number zs 4134
http://www.eseller.ch/product_info.p...4--vom-K4.html
thanks
thanks
#7559
i will pull the diff out and take pics so you can see what i mean as for wheel nuts coming off dont use alloy nuts with nylock thay are crap i use nuts with out nylock but the face has a washer built on the end with a seration on them and they never come off they actauly bite onto the wheel alot of people use them in nitro racing and thats where i got the idea from they cost around $8 for 4 well worth it i will get the name of the product for you when i get home again along with pics of the diff mate
#7560
Off course, when one comes of one time you need to throw it away and get a new one for about 0.25€/piece.
Oh yes, they tend to be renewed once a year...
