Yokomo MR4TC-BD
Old 08-13-2007, 04:09 AM
  #7531
mattwoodcraft's Avatar
hay guys i wrote a while back about diff problems blowing up all th e time if you dont mind a little extra weight try using the sd rear steel out drives and hardend drive shafts with acer ceramic bearings . you have too use a few mor shims but no more diff problems and no more wear when running brushless just thuoght i wiold let you all know as i was going threw so many diffs ... its certainly worth a shot and in important races it doesnt let you down
mattwoodcraft is offline
Old 08-13-2007, 05:53 AM
  #7532
Christophe Blandin from Select Model Shop is selling some black RW spur gear. He told me that they were specifically done for him on his demand.
You can contact him at [email protected]
I'm sure he shipped in Europe and he certainly can ship worldwide.
canto54 is offline
Old 08-13-2007, 11:21 AM
  #7533
I believe RW are going to do them in black aswell now, as far as I know. You can dye them yourself using some plastic dye from hobbycraft.
John Pape is offline
Old 08-13-2007, 11:23 AM
  #7534
yokemad's Avatar
hi guys
Can Anybody tell me where can I buy Team CREST chassis kit or any other Carpet Chassis sellers
I can also appreciate for Any tips for carpet setup
Thanx in advance
yokemad is offline
Old 08-14-2007, 09:06 AM
  #7535
m3ndo5a's Avatar
Yoke Guys/Gals
I just lowered my price on some parts....pretty much a give away or BOGO
LMK
http://rctech.net/forum/showthread.php?t=165886
m3ndo5a is offline
Old 08-15-2007, 02:46 AM
  #7536
Hi all,
I have a Yokomo MR4-TC from about 2001 era around the time of the custom..
What is the difference between that belt driven car and the current BD car??
I would love to know? I am thinking of getting back into racing and wonder how out of date my car is
Wylie27 is offline
Old 08-15-2007, 07:05 AM
  #7537
yokemad's Avatar
Does 90T 48dp spurgear fits to Yokomo Bd If not what size is the Max for 48dp
thanx in advance
yokemad is offline
Old 08-15-2007, 10:15 AM
  #7538
Pretty sure 85t 48dp is the largest you can fit.
Old 08-15-2007, 02:13 PM
  #7539
87 teeth 48DP
will just cache on the front egde on the hole under the spur but i just filed it to a 45degree angle with a file and its fine.
blazer2 is offline
Old 08-15-2007, 03:31 PM
  #7540
Island Losi's Avatar
what knid of shims are u adding and how much?
Island Losi is offline
Old 08-16-2007, 03:27 PM
  #7541
yokemad's Avatar
I put 86T 48dp Spur gear without a Problem
yokemad is offline
Old 08-16-2007, 03:36 PM
  #7542
I fitted a 88T "RW" spur : no problem!
il-gufo is offline
Old 08-16-2007, 03:49 PM
  #7543
kermit's Avatar
Originally Posted by John Pape
Chris is the biggest tart, both the towers have been dremelled to give the appearance of lowered and the top holes countersunk to reduce the chance of tweaking the cars.
The steering is the CGM version we are using now.
We do not use the Masami tower.
What is the advantage of CGM steering over the BD?
kermit is offline
Old 08-16-2007, 07:58 PM
  #7544
crabboy's Avatar
Trader Rating: 58 (98%+)
More turn of the front wheels, standard about 17degs with the CGM parts about 27degs, we run it on both of our cars.
crabboy is offline
Old 08-16-2007, 10:58 PM
  #7545
dodo's Avatar
is there any step by step tutorial and part numbers somewhere on the web on this? sorry if this was asked and answered before.
dodo is offline
