Yokomo MR4TC-BD
#7517
I have been using them as you say for years, they work great for me, never had a problem with them coming off or getting loose. Its nice real nice having the allen headed ball studs also, makes for quick and easy camber height adjustment. I even just unscrew the ball studs instead of popping the link off when changing the diffs.
#7519
Does anybody know what the purpose of the lower rear tower seen on Chris Grainger's car in the Euro's picture?? Is it a standard tower or a Masami rear tower? also looks like there is a lower tower on the front as well???
#7521
The top screws are countersunk and they are much closer to the top edge of the shock mount than standard, compare it to to your own car and you will see, front looks similar to the rear.
#7522
OK I need some hard core advise from people in the know.
What spool and driveshafts do people use on the BD.
I ran the new Yokomo alloy spool on the weekend and it was a peice of JUNK, only put 4 packs through it and it was worn so badly in the slots I couldnt use it any more.
I see a couple of pics of drive shafts with blades on, I need to know what spool and drive shafts work together.
Ive got some alloy rear diff halves but after the spool Im to scared to use them.
Im using it on my Scythe but its for the SD/BD
http://www.rcmart.com/catalog/produc...ducts_id=20235
#7523
i am not sure about the cyclone steering but i think it is the cgm steering parts, sd202g and zs4134 just married it up with my car and the front tower seems alot lower that my BDM
#7524
With the alloy diff halves I would advise buying some corally blades and filing the slots out to 2.5mm to accept them. You can run without and just keep lubing the ends. But personally I'd buy the blades and file the diff halves, they are not cheap after all!
#7526
Chris is the biggest tart, both the towers have been dremelled to give the appearance of lowered and the top holes countersunk to reduce the chance of tweaking the cars.
The steering is the CGM version we are using now.
We do not use the Masami tower.
#7528
Black Spur?
Best bit i like about Chris's car is the black spur - where can you get those from?
#7529
Stuart
It's just a white RW spur gear dyed black. (Refer back to John's statement about Chris being a tart)
Stuart
Stuart
#7530
What do you dye them with?
