Yokomo MR4TC-BD
#7111
Regional Moderator
Rumors
As for the rumors of Yokomo not producing any kits, I am a Yokomo dealer and I have no problems getting any of the parts or the kits. In fact, Yokomo has been one of the easiest companies to get parts from that I've ever done business with. However, I was recently told by a rep from another company, that Yokomo USA may shut down. I'm unsure if there is any truth to this though.
#7112
Regional Moderator
Droop
So, I'm struggling to find the correct amount of droop on my BDM. Most set-up sheets give a droop value of 4 to 6. My 1st question is = When set at these values, should the arms be about level with the chassis or above, or maybe below level?
I realize the results will vary depending on overall shock length, which can be greatly altered by modifying the the plastic insert inside the shock as shown in the Chris Granger set-up guide.
Any useful input on this will be appreciated.
#7113
#7114
shock length won't affect droop but it will limit suspension travel.
so yeah it will affect droop indirectly in a case where the max suspension travel (measured from shock mounting pos at lower arm in respect to mounting pos at shock tower) is longer than the shock length.
#7116
depending of the shims you use / or not use under the inner suspensionarm mounts
#7118
I think my main concern is; Is it normal for the arms to be above level (pointing up) with a droop value of 5.
#7119
Originally Posted by crabboy
Dude a new chassis, yeah about 6 months ago, abd ya link dont work.
yokomousa shows new part number BD-002MG. maybe this is another new chassis.
i have the harded chassis, don't remember the part # i think is was the 002G
#7120
Originally Posted by asw7576
Dude, Yokomo is releasing new BD chassis ( BD-002G ). That's why older version of BD chassis is hard to get in the past 4 months.
I already pre order BD-002G from www.pro-s-futaba.co.jp. I'm waiting it now, maybe next week will be arrive in my home.
i think the new one is the one in the above post.
#7121
Originally Posted by dodo
actually I just got a BD and haven't do the setup. I will see and update again.
BD with Xray ball cups is really a tough car
#7122
Dude, why you switch ?
even without XRAY ballcups i feel that the stock ones are tough enough. still yet to run the car, keep the tips coming
#7124
Originally Posted by VooDooPH
hate the stock yok BD/SD ballcups... always had a problems with the steering cups popping out during races. got some RPM ones but would like to switch to the captured Xray ones...
