Yokomo MR4TC-BD
#5551
Originally Posted by Tpg racer
Hey guys just being curious, is the Yok.BD better than the Hpi Pro4???
Any input would be helpfull.
#5552
any of you guys know if yokomo makes a CARBON FIBER UPPER PLATE for the foam bumper? part no? if theres none from yokomo, you guys know what brand makes it? thanks in advance for any info
#5555
Originally Posted by pops
Square makes one and you can get it from Speedtech.
#5556
URGENT: Top and Bottom decks!
Today at the track I had a huge crash into a gutter at full speed in modified. I am not sure what the cause was, I think it was either:
1. Lost signal somehow and the failsafe didn't kick in quick enough.
2. The servo horn just snapped by itself during the run, causing me to loose steering and go straight into the gutter on the side of the track.
The crash was quite fatal, snapping the top deck, splitting the bottom deck, snapping a arm, bending a hinge pin, bending the front hinge pin mount and snapping the servo horn (or maybe the servo horn caused the crash?)
Anyway, I can get all these parts apart from the decks. To get the distributer here to get them in will take 3 weeks or so, and I dont have that much time. All the sites are out of stock, or don't sell them. Speedtech has the top deck, but no bottom deck.
So I am asking if anyone here has a spare, new, top and bottom deck that they could sell to me so I can make a big meeting in 2 weeks time. Or if someone would be kind enough to order the parts from Yokomo USA on behalf of me, then send to me.
Please let me know ASAP
Sam
Sam
#5557
The SDW bumper plate is graphite, this comes with the Grainger kit. I've never seen the Square one so I can't really compare though!
Sorry Sam, I had to use my spare after I leant on my modded one and snapped it!!!!!
#5558
Hi,
@Sam: Try to contact Markus @ www.rc-car-world.de
He has good prices and good customer support.
Cheers
Chris
Cheers
Chris
#5559
Originally Posted by crabboy
Hi,
Heres a pic of my bd with lexan trasnponder mount (done in carbon fibre) and bomer white belts
thanks
#5561
i am not crabboy but i do have the #
so
TB20022 for the front
Tb20023 for the rear
so
#5562
Got the Bomer belts from my LHS here in Adelaide, for the internet shoppers Speedtech sells them to.
Dont know if they do anything different to the black belts, but they do look cool.
I tested them and they are more durable!!!
maybe the car rolls more with them!!!
#5563
Hi all,
I'm currently looking for a tourer to replace my RDX, I think I'll be going for the Yokomo but I still have a few questions which drivers can answer more honest then shopkeepers.
Is the Masami edition worth the extra 110€??
How rigid is the car (or, will stuff break easily)??
How durable are the diff outputs/ one way outputs, cause I noticed they dont have the blade system -> more info, I'm driving a 4.5r
(xtra, whats the best way to sell an "in good condition RDX" in Belgium...)
Thx for the time and possible answers!!
Dirk
Dirk
#5564
i don't believe you'll break stuff anymore than other cars. it is a strong car but . . . anything can be broken
Outdrives are currently not blade type but are durable when using grease, and very inexpensive to replace too.
hope thats some help
#5565
well the masami edition has the new rear shock tower, bomber white belts, ti screw kit and the new yokomo white springs and some differnt driveshafts i think. from what i understand this is extremely good on smooth tracks, but the new rear tower doesnt mix well with bumps. so it kind of depends on what tracks you are racing on, but id get the masami editon anyway, its got to be better, and if you run on lots of bumpy tracks, its hardly much to get an old shock tower and try that aswell.
stuff doesnt break very easily i dont think, but i would get the wide front bumper, as this saves the front hinge pins and wishbones, infact it protects the entire front end of the car. but no, generally its not that weak, iv hardly broken a thing.
the oneway outputs hold up very very well, the rear diff outputs do wear a little more, but they are very cheap, and it is possible to get the excel outdrives which are made of delrin, and are very good im told. that said, iv had my BD a while now and never replaces the diff outputs.
and on the motor front, you have no worries, theres actually loads of room in the BD for the BL speedo's. also, iv been running my 7 turn checkpoint loads with no issues on the drivetrain. hope that helps ya
