Yokomo MR4TC-BD
#4936
What I mean is that the Masami edition has a lot of new parts on it. I really believe that the stock BD setup needs to be changed for the BDM. That is what Im looking for. A good starting setup for the BDM not the BD. I'd rather not start from scratch or the stock BD one. Sorry for the confusion
#4937
Originally Posted by Zacharopoulos
Guys this must be the drive shafts that come with the Masami version!!
#4938
Just start with the std setup it won't be far off, but what surface(s) are you planning on racing on as some bits may need tweaking?
#4939
Originally Posted by tony q
i don't like them due to they are so easy to break especially using it the front w/ oneway, i have one that came w/ my SDW and change it to hard universals. no problem ever since.
#4940
So at last , is there any difference between the " steering system " of Masami edition and the single BD??
#4941
I don't think so.
Has the masami ed. chassis got the outer servo post removed and the lumpy bit? ( or whatever its called!) Just wondering if it is, what do the instrcutions suggest you secure the servo with? I doubt it says ShooGoo
#4942
Yes there is a diference.
Look: http://www.rctech.net/forum/attachme...hmentid=132702
tony q / Zacharopoulos: yes, people here are replacing the front with the Stainless steel ones as posted in the last page. They are far more stronger!
#4943
ok can someone please outline the differences in the steering system on the masami, as i cant see them, perhaps im just being stoooopid , cheers
#4944
The Masami edition has straight steering posts, unlike yours
#4945
i think its the steering posts are different so the belt doesnt rub on it like it does on the old versions of them.
#4946
The only difference is that they have spacers under the bellcranks to clear the belt. Normal BDs now come with these aswell.
The Masami version still has the bump for the servo posts.
#4947
ooooooo rob thats low , ill have you know its all straight again now, hence my half decent display at broxtowe, unlike ashby with my made up car haha
#4948
What do you mean straight steering posts?? I own the newest version of the single BD and has EXCACTLY the same steering plate , posts , washers under bell cranks etc!!
IS there any other difference??? Maybe i am stupid but i can't understand what are you talkingabout guys
#4949
#4950
I just bought the ceramic bearings for BD !!! I thought that it will be better to let them open from one side!! They will spin more free!!! Would you do that ??? Will they have any problem at the future?? any matter of dust or...??
The life probably shortened too.
