good beginner on road car
I have done my fair share of off road racing I'm looking to try out some on road racing. The track in which I will be racing changes week to week its an asphualt parking lot painted with a series of islands and they connect them in different configurations every race day. The pavement is kinda rough asphaul,it is cracked in some spots. Its pretty high traction though ,they spray it with some stuff that when walked on its like fly paper.
I was wondering what a good starter car is. Guys at the track run a lil of everything from associateds to x ray. So its hard to say what the fast guys are running because they all run different cars. I kinda wanted to stay away from belt cars only because I'm worried about belts being chewed up. If I am wrong about the belts being an issue please correct me. Though that being said I was kinda leaning toward a rtr tc4 what do you guys think.
What classes are they running? If it's VTA then you'd be better off getting the TC4 club racer and adding your electronics. If they're running usgt or 17.5 tc then the rtr might work. Your best bet is to go out on a race day and talk to the guys running and get their opinions, There are lots of good lower priced options like the Xray T3r or Schumacher MI1. If they blow off the track really well before they setup a belt car shouldn't have any problems. Just keep a set of belts and pulleys for spares.
It's important to start right ! Whatever car you get, you will need to familiarize yourself with the Rc Crew Chief software, so you will understand what the adjustments will do to your car... By the way, the tc4 is the best beginner car out there, period !!!!!
They run what they call a silver can stock class as well as what they call gt2 which is 17.5 and gt1 which is unlimited.
I'd go a belt as IMO belts have a much lower chance of chewing up the pulley or snapping a belt compared to chewing up the spur in a shaft drive. I'm not sure how vulnerable the TC4 spur is to rocks though.
If they spray the track with something before hand it might not really matter that much though. Depends how clean the surface is beforehand I guess.
If you are looking for a dirt cheap belt car, look at the 3racing sakura zero s. Cheap and cheerful with a full upgrade path to the regular version.
3 racing is not good for beginners. cheap price cheap quality and part availability may be and issue. I have an FGX F1 it is very fragile and parts fit poorly.
I recommend Tamiya or Associated.
Tamiya has arguably the best quality. parts all fit perfectly. you only need a phillips screw driver, the TT01 is a great beginners car. parts should be plentiful.
The Associated TC4 is probably the better car of the two. it is very durable, diffs are enclosed. parts should be plentiful. The TC4 is the updated version of the TC3, I still have my TC3 purchased in the early 90's when they were first introduced.
Ask the LHS what they recommend, experts and club racers have a totally different take on it. Beginners need durablitly and parts availability.
Remember this: for beginners is 10 percent car, 10 percent setup and 80 percent driver
for club racers it more set up.
Belt cars are good, what ever has parts availability. you will be hitting things. I still do.
hope this helps. you can also talk to the race director at your track what car they recommend for beginners and what is the best class.
Hope this helps
I also think that the Tamiya M05 pro is a great car, easy to drive and its very durable. although the class is highly competive with skilled drivers.
Hope this helps
The 3 racing is a no for beginners. cheap price, cheap quality. I have the FGX f1 and parts fit is poor and fragile.
I recommend either Tamiya or Associated.
Tamiya makes arguably the highest quality car kits. part all fit perfectly, if they dont you made a mistake. all you need is a Phillips screw driver to assemble. the TT01 is a great beginners car. parts should be readily available.
The Associated TC4 is probably the better car, it is the updated version of the TC3. I still have one. purchased when they were first release in early 90s. very durable, diffs enclosed, and parts should be available.
know this: for beginners its 10 percent car, 10 percent set up, 80 percent driver. for intermediate drivers its more set up.
talk to the race director. Ask them
what car they recommend for beginners and what class you should race in.
intermediates and experts have a different take on what to recommend. Beginners need durability and parts availability. you will be hitting things. I still do.
I also think that the Tamiya MO5 pro is very easy to drive and is very durable. it can take a serious hit. However that being said, the Mini Class is highly competitive with skilled drivers.
Hope his helps
have a blast.
Hope his helps
have a blast.
Hope this helps
Hope this helps
He's an offroad racer looking to get into onroad racing, not a total beginner. I would never recommend a TT-01 to anyone, but especially not someone interested in racing. The only racing a TT-01 is good for is racing against other TT-01s. It's not a good car, period.
Unless you're racing on a completely unprepped track, belts do not get chewed up. When I say unprepped, you see bits of asphalt and gravel all over. If your local racers run expensive cars like xray, I say that the race surface should be clean.
Most belt cars are pretty much the same design these days. Get a car that you can get parts easily for. If you are an Internet shopper, your choice window will be much bigger.
Shaft drive will be good to about 13.5, but anything faster, a belt drive is better imo. If you just want to run at a sportsman level, the TC4 is a solid choice.
I prefer belt cars, but will agree that as far as bang-for-buck goes, the TC4 club racer would be a good start. Cheap and parts are always available.
Maybe look at what is run / supported locally, get an idea of what cars parts & setup advice will be easily available to you.
The track actually belongs to the the Hobbytown USA in Fresno they carry tc6.1 stuff tamiya ta05 ber2 and the ta06 parts and the tc4. I will be running 17.5 sportsman or novice. A poster above said the belt cars are really only faster when running 13.5 or faster? As another poster said I'm not a complete noob I do race off road regularly and I'm usually front half of the pack. I will probably end up with a tc4 then and just stick my vtx10r with whatever 17.5 I can get my hands on. Thanks for the help guys.
