Ends for Fans to go into the Speedo (ESC)
Can anyone point me in the direction of purchasing the ends to crimp on for a fan to plug into the speedo. I need to free up space in the RX and want to plug in the motor fan to the speedo fan port...
I have attached a picture to show you the connector...
Is it something like this?
http://www3.towerhobbies.com/cgi-bin...?&I=LXBNDE&P=7
You can always cut your connector off and extend the wired and solder it to your esc (+)&(-).
The wires for a receiver are usually 26AWG etc, the picture shows 20AWG.
Will have a look at work
Generally motor fans are connected directly to the battery (at + and - on the ESC) to take advantage of the full battery voltage rather than the lower BEC voltage.
I think the best option wouild be to cut the wires off a fan you aren't using and solder the wires with connector onto the new fan.
I don't disagree there's probably some value in power stability supplied by a receiver, BUT i would like to share a problem I've recently run into with my rx-powered fan.
On my radiopost receiver, the fan turned out to be drawing so much amperage, it would inconsistently cause a total loss of control. I've since unplugged the fan and the problem went away. This didn't happen on my other car (which had a larger capacitor), so it was a pain to troubleshoot.
Direct hookup is definitely the way to go.
