GMVIS Commander Blues
Yes, I'm still fighting with my Commander.
It appears that the charger may be overcooking my packs. This becomes very possible after a raceday's worth of charges. By the end of raceday those cells are getting really hot and I'm afraid too much so. My packs aren't holding as many MaH as they used to. I'm using Peak charging for the most part although I've tried other modes as well. I don't have the temp probe. They seem to be completely unavailable - I can't even get Horizion to spec order one for me. I've found one in Hong Kong for $21 and $15 shipping, but I'm reluctant to buy offshore. Could my settings be messed up and if so which one. 6.0 amps 4620 MaH 11 volts If I have to get the probe, so be it, but if there's a way to get around this, I'd appreciate the help. |
Drop down the voltage if they are getting hot and also drop the peak detect. I just ordered the temp probe from HK along with some other goodies. Also you can set the mah to like 3900 but to say 4250 or what ever you put that won;t help either. I set mine as follows
6amp 3900 mah 30 mv delta peak 42 volt max Hope this helps, I look forward to useign the temp probe. The Program feature is real nice....Works awsome with the GM SX12 Hope this helps, -Stephen <>< |
Yeah I think that might help.....
but you kinda lost me on the "42 volts" thing. I'm thinkingthat temp probe might just be worth the hassle. Hey man, can I call you so we can talk about this charger thing? If yes, PM me with number and a good time. thanx PS: I wish I would have known you were ordering. I would have paid part of your shipping for a second problbe on that order :mad: . Originally posted by Mr. Shookie Drop down the voltage if they are getting hot and also drop the peak detect. I just ordered the temp probe from HK along with some other goodies. Also you can set the mah to like 3900 but to say 4250 or what ever you put that won;t help either. I set mine as follows 6amp 3900 mah 30 mv delta peak 42 volt max Hope this helps, I look forward to useign the temp probe. The Program feature is real nice....Works awsome with the GM SX12 Hope this helps, -Stephen <>< |
You got PM
Originally posted by drx Yeah I think that might help..... but you kinda lost me on the "42 volts" thing. I'm thinkingthat temp probe might just be worth the hassle. Hey man, can I call you so we can talk about this charger thing? If yes, PM me with number and a good time. thanx PS: I wish I would have known you were ordering. I would have paid part of your shipping for a second problbe on that order :mad: . |
