Old 12-26-2008, 10:42 PM   #14866
HMMMMMMMMMMM thanks
Tulsa TC3 is offline   Reply With Quote
Old 12-27-2008, 10:40 AM   #14867
rc pete's Avatar
Originally Posted by Tulsa TC3 View Post
how many people are running legal r.o.a.r weight in there cars and how are you getting them there using lipo
At the moment, I'm running a 4000 lipo (SMC), which is thinner (20.5mm high), so it gives you more options.
With that, I'm running a Manutech plate for both weight and balance... it gets it to within a few grams of perfect side to side weight balance. But the plate adds 2.5mm to your battery height, so you can't use the 5000's with it.
Then, to make the ROAR weight limit, I'm still adding on another 60g of weight, using the XRay bolt on weights... about 15g at each corner of the chassis (in front and behind the battery, and same on the other side. For these weights, you just have to make a counter-sink hole and you can add/remove weight as you like.
My next evolution will be an attempt to make 5000's fit. With SMC and TP coming up with 40C 5000 Lipos, it'd be nice to have the extra punch. I've got some tungsten weights coming in, which should fill in the battery slots. That will replace the Manutech plate and should provide more clearance for the 5000's.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 12-27-2008, 10:22 PM   #14868
I have a question about my rear diff pulley, it is wobbling side to side and I don't think that is normal. Is there a way to correct that or do I need to replace it(I cant my my scre driver small enough to check) let me know, thanks
Old 12-27-2008, 11:55 PM   #14869
do you have the washers between the bearings and the pulley? or has the pulley got a twist in it. if not then im not to sure
subdriftr is offline   Reply With Quote
Old 12-28-2008, 03:34 AM   #14870
Matt Pocknell's Avatar
If you mean that you can move the pulley from side to side then thats normal, its just how a diff works. Once the car starts moving, the pulley will straighten itself out and run true.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 12-28-2008, 04:05 AM   #14871
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
just wanted to ask what's the effect of inboard front toe-out in the TC? out of the box it comes with 2.5deg toe-out right? that's a bit much compared to the past touring cars i've used...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-28-2008, 04:59 AM   #14872
shadow102's Avatar
Trader Rating: 21 (96%+)
Its technically called front arm sweep. And 2.5 is ok if your running a spool. I prefer using the 1.5 block though and if using a one way on carpet 0 seemed to feel the best
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 12-28-2008, 05:18 AM   #14873
yokemad's Avatar
Hi Guys
First of All I want to say Well Done To you All Cyclone Drivers...
I've recently got an WCE from my mate which is almost Brandnew just to try and see what is Cyclone feels like on track...
But as an Xray Driver I'm very disappointed with the overall part quality of the car...
Rear diff is the Worst I've ever mate...
I can't imagine how does an Cyclone S owner feels LOL
Is there any place to find setups from 2008 events I need a good starting point for Low-med and Medium Grip indoor Carpet Track
Thanx in advance for your help and advices
yokemad is offline   Reply With Quote
Old 12-28-2008, 05:56 AM   #14874
jag88's Avatar
Originally Posted by yokemad View Post
Hi Guys
First thing you do is get the Pro diff.. It will go from the worst..... to the best you've ever built !!
jag88 is offline   Reply With Quote
Old 12-28-2008, 06:26 AM   #14875
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hi Guys
I just gotta ask - define "worse" diff ever?? I've built them all and if its built right - its just as good, if not smoother than the xray diffs...I know they are known for breaking the diff screw, but that doesn't sound like your problem with the diff...I'd try rebuilding it and go from there
jagg is right, the pro-diff is an improvement, but I wouldn't say its a necessity...I'm running the standard diffs in mine (mod, VTA, stock) and haven't had any problems other then a rock in the gear
As far as setups, give this link a shot
http://www.petitrc.com/view_news.php?id=4553
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-28-2008, 07:05 AM   #14876
VooDooPH's Avatar
ok. thanks! so if i'm running spool i'd be better off running the stock 2.5deg "front arm sweep"?
was running mod 4.0 the other day with 1.5deg front arm sweep (didn't change it after running stock with a one-way)... snapped the front drive shaft after powering out of a corner. could this be the reason for it?
Old 12-28-2008, 09:07 AM   #14877
John_S's Avatar
A 1.5 is the standard front block for team drivers on asphalt
John_S is offline   Reply With Quote
Old 12-28-2008, 09:54 AM   #14878
VooDooPH's Avatar
thanks!
Old 12-28-2008, 10:51 AM   #14879
yokemad's Avatar
so R you saying 2.5 is better on carpet @13.5 Class???
Old 12-28-2008, 10:55 AM   #14880
RC MARKET's Avatar
1.5 deg is Ok !
Hara had use 1 deg
RC MARKET is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
