Old 12-19-2008, 10:20 AM   #14806
now how do I do this? I also I wondering if the new tc arms part number 67717 suspension arms fits all four corners of the cyclone, I am wondering because the package does not say front or rear and the TC uses them all the way around
Tulsa TC3 is offline   Reply With Quote
Old 12-19-2008, 10:23 AM   #14807
STLNLST's Avatar
Trader Rating: 17 (100%+)
There's still a front and a rear arm for the TC. It doesn't use the same arm on all four corners.
STLNLST is offline   Reply With Quote
Old 12-19-2008, 10:32 AM   #14808
You get one front and one rear in a package, That is why it doesn't say F or R.
Hope that helps
Lazer Guy is offline   Reply With Quote
Old 12-19-2008, 10:32 AM   #14809
John_S's Avatar
You need 2 packs of the suspension arms to do the car and you need a digital transmitter to do your epa adjustment
John_S is offline   Reply With Quote
Old 12-19-2008, 01:00 PM   #14810
Coldn's Avatar
Send a message via MSN to Coldn
Originally Posted by Itchy View Post
On low traction tracks i have found pushing the rear arms forward generates a lot more on power grip. You will loose some on power steering.
Reducing the punch on the ESC and/or puting a milder motor might be a good ideia. 4.0 and lipo is not easy if you dont have traction.
Boa sorte
Thanks, I am realy new in setup car. can you be mor specific with the pushing the rear arms forwad
Sorry but i dont understand what arms you saying
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 12-19-2008, 04:04 PM   #14811
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
Hey guys. I'm thinking about picking up a sedan and was wondering if one of you could give me a good rubber on carpet setup to start with aswell as starting point for 13.5 gearing.
Thanks alot..
David
D Hunt 3 is offline   Reply With Quote
Old 12-19-2008, 04:06 PM   #14812
edseb's Avatar
Originally Posted by trickd122 View Post
Where DID you get those weights from?
Oh man, I ordered those a while back and honestly can't remember which online place it was. I think it was somewhere out of Hong Kong if that helps narrow it down. Sorry I can't be more help. If I find out I will post the link.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 12-19-2008, 04:08 PM   #14813
edseb's Avatar
On the inner hingepin where the arms are mounted you can move the arms forward or back with the movement of the washers. If you want to move the arms forward, just put the washers behind the arm on the hingepin.
Carl Hyndman
Old 12-19-2008, 05:32 PM   #14814
so when I set the EPA in my transmitter will I need to adjust the steering rate at all, or would it just depend on how the car steers for me?
Old 12-19-2008, 05:39 PM   #14815
edseb's Avatar
When you set your EPA, set each side so that the max throw is when the steering knuckle is flush with the caster black. You don't want it going further or it will twist. From there you can add less for feel or adjust less with dual rate, not more.
Carl Hyndman
Old 12-19-2008, 05:43 PM   #14816
STLNLST's Avatar
it should depend on how it works for you.
Old 12-19-2008, 09:20 PM   #14817
Oh and thats my bad about the arms I should of looked harder! LOL
Old 12-19-2008, 09:25 PM   #14818
Has anyone ever looked into what kinda of servo arm gives you the best clearance from the belt. I run a Jr metal gear
Old 12-20-2008, 12:11 AM   #14819
EJ20's Avatar
Never Mind!
EJ20 is offline   Reply With Quote
Old 12-20-2008, 08:57 AM   #14820
I usually just use the one the servo comes with, someone has to know this?
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
