Old 12-09-2008, 07:11 PM   #14686
shadow102's Avatar
Trader Rating: 21 (96%+)
i recently received a PM about this but for anybody wondering how to wire in a Tekin RS for their cyclone:
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 12-09-2008, 07:19 PM   #14687
Herc Driver's Avatar
And the little nubs (probably not the correct term) fit the slots under the chassis fine? All versions (Moore edition)?
I only ask is because my last competetive tourer was a TA05 that I put a 3 racing chassis on and discovered the batteries wouldn't fit without being jerry rigged. So after $100 chassis I had to go back to the ol' plastic one (should have done more research).
Thanks for the replies...just don't want to make a mistake/I have gone all lipo.
Thanks for the earlier photo as well...any of the battery in the chassis slots? Again thank you.
Herc Driver is offline   Reply With Quote
Old 12-09-2008, 07:38 PM   #14688
shadow102's Avatar
If you are going to run the cyclone TC the slots are larger so the battery will fit with lots of room to spare. The older cyclones still have plenty of room for the humps. Even so when you file the chassis down to re seal it you can make the holes bigger or angled. And sorry a picture of my chassis would do no good as i run a lipo plate and have ground my battery humps off
www.nexusracing.com
www.go-rc.org
Old 12-09-2008, 08:43 PM   #14689
bigz's Avatar
Originally Posted by shadow102 View Post
Couple things to think about. Pick up a set of 1.1mm 3 hole shock pistons made a large difference in my handling. You can use springs from alot of different manufacturers, if you have anything left over from the xray you can use them but to get started you can go with the Pro4 spring kit although you wont use much over the white springs.
For parts you can also look at speedtechrc, amainhobbies, and tower
are you using the 3 hole pistons on all shocks or only in the rear? what shock oil are you using?
got these pistons and installed them in the rear.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 12-09-2008, 09:29 PM   #14690
CHRIS CHAVEZ's Avatar
I have an old school question.
Do any of you guys remember what the internal drive ratio of the Moore Speed Cyclone with the upgraded 18tooth center pulleys is?
Thanks, Chris
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 12-09-2008, 10:06 PM   #14691
birdman's Avatar
Thanks, Chris
Chris,
It's 2.1667.. if it is 16T then it's 2.4375
birdman is offline   Reply With Quote
Old 12-09-2008, 10:13 PM   #14692
Originally Posted by birdman View Post
Chris,
Thank You Very Much, Chris
TQ RC Racing
Old 12-10-2008, 01:14 AM   #14693
Lonestar's Avatar
Yes - the "shaped" orion packs drop right in the existing slots in the chassis. I use 3800's in my Hara Ed.
I used to have platinum 4800's but I sold them as I was tired of loosing the pack during the races, no matter how much tape I used (granted, the tape wouldn't rupture if I didn't hit anything, but, hey, we're all humans )
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-10-2008, 03:35 AM   #14694
shadow102's Avatar
I am using the 4 hole pistons with 40wt all the way around
www.nexusracing.com
www.go-rc.org
Old 12-10-2008, 04:10 AM   #14695
Does anybody use the titanium racing spool? Is it better than hot bodies (3) spool?
wassermann is offline   Reply With Quote
Old 12-10-2008, 06:23 AM   #14696
mangoman's Avatar
If you mean the TIR spool, dont get it as the outdrives break easily....
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-10-2008, 06:39 AM   #14697
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Does anyone know where I can get a LiPo tray that will fit the Black Edition Cyclone and take the IP 3800 25c Battery??
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 12-10-2008, 07:25 AM   #14698
mangoman's Avatar
Thanks!
Doesnt the IP 3800 fit the cyclone (not much clearance though)??? I have a bitty designs lipo tray but i havent tried it.
www.smaracing.org
Old 12-10-2008, 07:54 AM   #14699
shadow102's Avatar
The picture I posted below is the ip3800 on a pdp lipo plate. I shaved down the humps and I have a ton of clearance but even before shaving them off I had room if you shave the bulkhead down
www.nexusracing.com
www.go-rc.org
Old 12-10-2008, 08:51 AM   #14700
Another question to the titanium racing spools.There are two different spools:
1.US-spec spool
2.Pro comp. spool
Which one is better and why.
Thanks Michael
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
