Old 12-05-2008, 02:34 PM   #14656
Send a message via AIM to munrath
where is this guide of hara build tips?
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 12-05-2008, 03:19 PM   #14657
here
the translation is a bit weird, but you should get the idea.
kingpops is offline   Reply With Quote
Old 12-05-2008, 06:59 PM   #14658
harabigfan's Avatar
Hi there.. i check the translation but still puzzle why doing like this.. the heating?
I quote the translated text, "If you take part in this very astringent, and by heat"
I still no idea
harabigfan is offline   Reply With Quote
Old 12-06-2008, 12:06 AM   #14659
Korey Harbke's Avatar
Usually when you warm up the plastic a little bit like that, it helps it "fit" to the ball a little better. So it will free up the link a tiny bit. I usually take a lighter and get the link warm, and lightly squeeze it with needle nose pliers. That just helps free it up even more.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-06-2008, 06:20 AM   #14660
trickd122's Avatar
Default tuning with droop
I know obviously each track has different droop requirements, however I have always just done whatever everyone else is doing.
How do you know when you have too much or too little droop?
How does droop affect traction?
please be as detailed as possible..
trickd122 is offline   Reply With Quote
Old 12-06-2008, 10:48 AM   #14661
Originally Posted by kingpops View Post
arms, c hubs, steering blocks/rear hubs and outer hinge pins. That is all I have gone through in 6 months or so of racing. The arms seem really brittle and do not take much of a hit to break, but my home track is pretty hard on cars though. I keep pretty much one of everything(bar chassis and shock towers) in my pit box, but I hate not being able to fix the car if it does break. The stock hinge pins have all broken in my car, but I got the ti coated ones and they have been really good, with only one failure, but it was a big hit that broke it
I would also get some of the HD ball cups and use them all through the car(steering etc) as they have less slop than the others. There is a guide to building which Hara shows how he builds his cars, and that has some good tips which will make the car more reliable and easier to work on. IMO the ball cups on this car should be treated as a consumable and replaced every time you rebuild the car.
Where do you get the HD ball cups from? My car is fairley new and noticed the amount of excessive slop in the steering links .
dannybcaitlyn is offline   Reply With Quote
Old 12-06-2008, 11:31 AM   #14662
ShaunMac's Avatar
The HPI HD 18mm Balls Cups are HPI #A302
Tower and HotbodiesOnline have the HD Ball Cups. Just search for A302 and it should pop right up.
ShaunMac is offline   Reply With Quote
Old 12-06-2008, 10:52 PM   #14663
Shagnasties's Avatar
Default lipo fitment
Heya, do lipo packs fit into this car without modification or upgrades?
cheers
You dont "snuggle" with MAX POWER, you strap yourself in and feel the "G's" !!!!
Shagnasties is offline   Reply With Quote
Old 12-07-2008, 04:36 AM   #14664
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
running with Orion 3600/3800 with the plastic battery tray. fits fine. just need to peel part of the top decal off since it snags with the bulkhead. otherwise, it fits fine.
i've seen a few running SMC 4000 packs and Orion 4900 packs back here... i don't think they use the plastic trays though.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 12-07-2008, 05:41 AM   #14665
shadow102's Avatar
Trader Rating: 21 (96%+)
hey guys i need to order some axles for my car. tower is currently out of the HD 44mm front axles...but they have the rear ones. What is the difference between the front and the rear axles i assumed they were the same.
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 12-07-2008, 09:25 AM   #14666
STLNLST's Avatar
Trader Rating: 19 (100%+)
Good run with the car yesterday. We tested a few things throughout the day and the car got better and better. Scotty and I were testing with two different chassis. The BMI and the stock HB cyclone 2mm chassis. Both cars were fast. Scotty was a bit faster but I'm going to give the driver the nod on this one. We also ran two different set up's. He had a spool and I ran a oneway. The next time out I'll be running a spool. In traffic I could have used some breaks and possibly gone deeper into the corners. Oh well....had a blast and can't wait for the next time out.
STLNLST is offline   Reply With Quote
Old 12-07-2008, 09:43 AM   #14667
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
is anybody using the chassis stiffeners?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 12-07-2008, 03:53 PM   #14668
The front axles fit all around and so do the rears, the only difference is the shaft is larger on the front axles.
Lazer Guy is offline   Reply With Quote
Old 12-07-2008, 05:53 PM   #14669
Zdiddy's Avatar
Hey guys, I have sold all my X-Ray equipment and am seriously considering making a switch to a Cyclone and hoped that some of you Cyclone owners would be willing to answer a few questions for me. Some (or all) of this may be addressed in the other 14,667 posts, but I just don't have the time or energy to wade through all of them. OK, here it goes. My LHS doens't currently stock Cyclone parts, although he can get Hot Bodies products and I will likely have him order everything to get me started and hopefully talk him into eventually stocking a few consumables for the car. I have looked on HB's website as well as Stormer Hobbies. HB apparently doesn't list all of the parts that are actually available on their website. I don't find a sway bar kit, but on Stormer's site I find a complete kit for the Cyclone S, will these work on the Cyclone TC? Stormer does list a complete set of springs. Are these all the springs that I might potentially need for asphalt and/or rubber tire carpet racing? I think some run HPI springs sometimes?? I have read that the hinge pins tend to break and should be replaced with Titanium ones. Again, I find these for the "S", but not for the "TC". Will these interchange? If and when I decide to order the car, I plan to order everything that I could possibly need for tuning the car, from springs, to pivot blocks, to sway bars, etc..... and a good assortment of spares (arms, c hubs, steering knuckles, etc...) I tend to like to do things first class right from the start, so do you guys have any other suggestions for add-ons? I see an option for purple Titanium links, are the stock ones in the kit not Ti? Does anyone happen to know if the Platinum Edition Orion 5000 lipo will fit without too much modification? How do you guys secure your lipos in the chassis? Sorry for the flood of questions, just trying to inform myself as well as possible before making the final decision. Any and all help/advice would be greatly appreciated. Thanks in advance,
Zach
Zdiddy is offline   Reply With Quote
Old 12-07-2008, 05:58 PM   #14670
Patriiick's Avatar
platinium 5000 fits fine... no mods needed.
i use tape for the lipos, and i have a spare body post screwed in the centerline (you ll understand when you will have the car) to prevent the pack from moving and hitting the spur in a crash.
Patriiick is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
