Old 11-27-2008, 08:02 PM   #14596
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by STLNLST View Post
Has anyone that has run any previous cyclones prior to the TC notice a difference in materials in the arms? I have broken two new TC arms running 13.5 while running 3.5 mod with the older arms and never breaking one. It could just be a freak crash but the other HB driver out here has experienced the same thing. Just curious to see if other's have run across it as well............
was running 13.5 on my TC's maiden run. after running less than 2 packs, my rear arm broke off where the rear hub suspenion pin mounts... also the suspension pin broke into 2 pieces. hahahahaha!
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-27-2008, 10:24 PM   #14597
STLNLST's Avatar
Trader Rating: 19 (100%+)
Looks like you might want to invest in some of the old arms.....LOL Sorry to hear that you had a crappy experience in under two packs. Did you get to run the car much after after you repaired it????
STLNLST is offline   Reply With Quote
Old 11-27-2008, 10:38 PM   #14598
VooDooPH's Avatar
unfortunately i didn't bring spares that day. wasnt expecting anything to break that soon. hahahahaha! I use to run my Xray T2'07 with a 4.0BL and the only parts i'd break were the drive shaft cushions.
but with the 2 times i was out on the track i found myself dialing down the steering EPA. this kit loves to steer (which i like). started with 40% epa on the 1st pack and gradually got myself to 65%. then the car broke.
Old 11-28-2008, 06:19 AM   #14599
Originally Posted by mmario777 View Post
Does anybody know what is the distance between the chassis and the top deck aluminum bracket on TC?
I wonder if the latest LiPo battery pack (5000 , 5500) will fit without any modifications.
If you grind off 1.5mm from the aluminum bracket over the battery you will have room for a 23mm lipo to slide in without rubbing. I was reluctant to grind it off but it's not a big deal at all and I think 24mm would fit OK.
I have the 2.5mm chassis, you will have less room with a thicker chassis.
Could someone give me the part # for the purple front lower balk heads ???
All I have is the # for the black ones.
Lazer Guy is offline   Reply With Quote
Old 11-28-2008, 08:38 AM   #14600
rc pete's Avatar
+1 on the grind option. You'll notice that the screw itself doesn't come through the bracket all the way. I ground mine up to the bottom of the screw.
I'm running an SMC 4000 Lipo (20.5mm height) + Manutech plate under it (+2mm), and it barely fits (~ 1mm gap).
Another Cyclone driver at our track is running the Reedy 5000 20c, but no plate... just a lot of lead around it.
The front purple lower bulk heads are #67706
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 11-28-2008, 11:15 AM   #14601
rc pete
Thanks for the #'s
Old 11-28-2008, 02:37 PM   #14602
mmario777's Avatar
Trader Rating: 15 (100%+)
rc pete and Lazer Guy,
Thanks for the advise
mmario777 is offline   Reply With Quote
Old 11-28-2008, 09:55 PM   #14603
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hows carpet going man?
Running 13.5?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 11-28-2008, 10:18 PM   #14604
rdur's Avatar
I was looking at Atsushi Hara's set up sheet for carpet and he has his shock springs labeled as 33lb in front and 28lb in rear. Does anyone know what colors that corresponds to for HPI springs or the springs that ship with the cyclone tc?
rdur is offline   Reply With Quote
Old 11-29-2008, 12:54 AM   #14605
Korey Harbke's Avatar
That's carpet on foam tires. I'm almost 100% sure he ran Xray springs. Now days a spring setup like that wouldn't work so hot in the first place. Now days we are running a 17-20lb rear spring, and about a 30-33lb front spring. Mainly because we now run the same compound of foam tires all around, as opposed to having a front tires with a really hard outer sidewall.
Color wise... I'm pretty sure thats xray violet and purple. those are both stiffer than the HPI pro 4/cyclone springs as they only go to about 24 lbs. It's geared for rubber tire racing, instead of foam.
Hope that helps some.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-29-2008, 08:02 AM   #14606
rdur's Avatar
That helps a lot, thanks. does anyone have a good cyclone setup for VTA rubber on carpet? Here is what i plan on starting:
FRONT:
Camber- 1
Ride Height- 4
Droop- 5
Diff- Locked spool
Stabilizer- silver
Toe- 0
Oil- 45
Spring- HPI pink
REAR:
Camber- 1
Ride Height- 4
Droop- 5
Diff- Diff
Stabilizer- none
Toe- 2
Oil- 40
Spring- HPI silver
Any suggestions would be greatly appreciated, thanks!
Old 11-30-2008, 08:07 AM   #14607
STLNLST's Avatar
Running 13.5?
Carpet is great so long as you can take the paragon fumes all day Traction is awesom and 13.5 is more fun than mod ever was.
Old 11-30-2008, 08:26 AM   #14608
cyclone speed's Avatar
hi guys , iv been out for a long time , nice to be back .
I was wondering what would you run with mod 5 cell with 3.5 on medium tight layout on medium bite carpet track ?
Thank you guys , its nice to be talking with you.
cyclone speed is offline   Reply With Quote
Old 11-30-2008, 09:56 AM   #14609
RCFREAK's Avatar
Trader Rating: 17 (100%+)
got a carpet setup to try?? we are running 13.5 no Paragon at our track anymore.. can you post or PM if possible??
Thanks.
Arv.
RC AMERICA// EA MOTORSPORTS// KO PROPO// ORCA
RCFREAK is offline   Reply With Quote
Old 11-30-2008, 10:07 AM   #14610
Scott B's Avatar
Trader Rating: 43 (100%+)
Thanks.
He was in the "B" main, so I don't think you would want his setup..
But, He said he did "win practice" so it might be something to try.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
