Old 10-14-2005, 04:44 PM   #1441
Nexus Racing's Avatar
Originally Posted by S-T-R-l-K-E-R
nexus racing - justo got my kit today. thanks for all. great service and fast shipping..
No problem. Check your pm
Originally Posted by rc-zombies
it should might be a little slow...
I think that's the hight torque version.
Hey rc-zombies,
Didn't you see pics somewhere of a dremeled front bridge (toe block) that left room for the steering parts when adding spacers underneath the bridge? Where are those?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 10-14-2005, 04:56 PM   #1442
rc-zombies's Avatar
Originally Posted by Nexus Racing
Hey rc-zombies,
haven't seen those pics...
I put 1mm spacers under mine...and have no problem with clearance.
Old 10-14-2005, 05:42 PM   #1443
Scott B's Avatar
Trader Rating: 42 (100%+)
Thanks rc-zombie,
As for the tamiya univ., the drive shaft is a little shorter, and the axle is the same but the mounting hole for the drive shaft is a little more to the outside so all togehter its almost the same length. Plus the tamiya axles have two sets of pin holes for mounting the drive shaft, so when one wears out you can switch it to the other.
I haven't run it at SWR yet, only on carpet at Stockton last Sat. with my new Novak Brushless. So I didn't do to well with breaking every run and trying to fing the rollout for the Brushless, but Billy and I are going to go next Wendsday night.
Mugen Racing USA, Gizmo Racing USA, Sweep Racing Tires, R1 Wurks...
"When I want the truth I go to the internet because that's the magical place where no one lies"...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 10-14-2005, 06:13 PM   #1444
Hmmm...I thought I saw you post something about a dremel fix.
The problem is when I want to add 1.5mm of spacers (like in one of hara's setups). It will give clearance at rest, but when I configure any significant amount of droop, the turnbuckle will hit the bridge when the suspension lifts. It gets even worse if I want to increase the ackerman.
I have 1mm under the bridge right now and it seems OK...but just on the edge. I was making these changes rather quickly on a race day, so I have not had a chance to look at it more closely...
NEXUSRACING.com
Old 10-14-2005, 07:00 PM   #1445
Well after being out of the hobby for about 5 or 6 years i'll be comming back sometime in the new year. And my choice of weapon will be the cyclone
~AR~ Gizmo is offline   Reply With Quote
Old 10-14-2005, 08:46 PM   #1446
When i get my Cyclone is there anything eles i should be getting?
Old 10-14-2005, 09:21 PM   #1447
rc-zombies's Avatar
ah...yes... I did say that...before I tested it out... now I'm running 6mm of droop..and clearance is not an issue. I'll probably dremel mine a little bit before I send out the toe-blocks to get purplized...
Old 10-14-2005, 09:24 PM   #1448
Trader Rating: 22 (100%+)
Does all the aluminum parts come anodized purple or black? My friend just got his and his is ALL purple. Very nice! I'll have to post pix of it the next time I see him.
JoeyE is offline   Reply With Quote
Old 10-14-2005, 09:24 PM   #1449
rc-zombies's Avatar
Originally Posted by Scott B
Thanks rc-zombie,
breaking... you need a p-dub bumper... or one of the p-dub me too's...Parma makes one now... super light and stiff... I'll be installing one this weekend.
or you can cut up some Kydex to make a wider bumper or do what every Pro4 racer is doing...using the bud's TC3 wide bumper plate.
Old 10-14-2005, 09:25 PM   #1450
rc-zombies's Avatar
all black... only the turnbuckles and toe blocks are purple.
Old 10-14-2005, 09:30 PM   #1451
Jeff Brown's Avatar
That is funny........... they all come from one source.
Rubberneck Racing.
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 10-14-2005, 09:31 PM   #1452
Hara hangs out here in Thailand a lot with Surikarn. I heard that Hara has a gf in Chaing Mai, haha. Maybe I'll have to get a Cyclone. I'll post pix of my friends purple Cyclone when he is finished putting it together.
Old 10-15-2005, 02:32 AM   #1453
Skill's Avatar
Raced last night on foams on carpet. Took a couple of heats to get a good setup and then the car was great. I ended up qualifying 2nd from a lower heat. In the final I got away well and then after a couple of laps collided with someone who was on the opposite side of the track. After that I made another couple of mistakes and then broke the ball stud which goes into the servo saver. I think I need to get some titanium ones of those
One thing that I did notice however is that my turnbuckle for the steering was rubbing on the F/R block, with no spacing on the block. I did rebuild the servo saver after the last race but I can't see anything that I put back together wrong.
Skill is offline   Reply With Quote
Old 10-15-2005, 08:12 AM   #1454
Doug D's Avatar
Trader Rating: 51 (100%+)
Does anyone know when the carpet chassis will be out? I think it will be 3.5mm....
Thanks.
Doug D is offline   Reply With Quote
Old 10-15-2005, 12:39 PM   #1455
Hollowman's Avatar
Send a message via MSN to Hollowman
Hara raced 4mm so i dont now
Hollowman is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
