Old 11-14-2008, 07:43 AM   #14491
cyclone speed's Avatar
Originally Posted by Lonestar View Post
cyclone speed
you are overcomplexifying this big time.
build your car as per instructions. check symmetry on droop gauges. lift the front wheels, adjust with the rear shocks, do it for the rear too and you're set.
The rest, ie the way the "real" weight is distributed on the chassis, cannot be changed unless you add lead in strategic places. Front and rear weight remains constant, left and right remains constant, if the right side is light it will always be but in terms of handling at the first order you can always compensate a lot of it with the shock preloads
Re your rear leaking shocks, if it leaks from the top the membrane is shot.
Paul
Paul
Ok , sorry for all the noob question , i apologise .
What is the membrane ?
cyclone speed is offline   Reply With Quote
Old 11-14-2008, 08:01 AM   #14492
Originally Posted by lightfoot View Post
I am soooooooo glad I read your comment... I just purchased 4 scales and was having a hell of a time trying to figure out how to move my weight around the chassis... I found myself spending 30 + min screwing with the shock preload and I gave up... I didn't know what the hell I was doing Now I will attack the problem again like you suggested ( shocks detached ) , move my weights around then de-tweak on my Hudy board... If anyone has any suggestions or tips on de-tweaking with scales I would love to know... Thanks...
Charles, bring your scales to the track. I will tell you how to do.
Thanks,
Hi-LowBlow is offline   Reply With Quote
Old 11-14-2008, 09:13 AM   #14493
Korey Harbke's Avatar
Honestly, I never use scales to detweak my car. I weigh each individual electronic component I put in the car though, and add weight accordingly to balance those things out.
But to actually un tweak the suspension, I take the shocks off and loosen all the bulkhead screws and upper deck screws to let eveyrthing relax. Then I plop my car on my new PPD Billet Tweak plate as it bolts the chassis to a flat peice of aluminum. After the car is bolted down I tighten all the screws back up again. You can accomplish the same thing by pressing down on the chassis when the upper deck screws are loose, but I think the PPD billet plate is a very easy, and effective way to untweak the chassis (as long as there are no bent parts).
Then I will measure the shocks, and make sure they are the same left to right. Then I will measure rebound and make sure they are the same left to right. Then I put the shocks aside and make sure the arms have the same amount of downtravel left to right. At that point I'klll put the shocks back on, and put everything in my car except the body to set ride height and do some final tweaks on the preload to make sure everything sits right. I always use the tip on an xacto knife to lift up the chassis from the bottom along the centerline to make sure the left and right tires lift up at the same time. Then I do the front the same way.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-14-2008, 09:21 AM   #14494
Originally Posted by 2056dennis View Post
so lazerguy should the numbers be the same front to back or just side to side right now they are the same side to side but not front to back
Hi Darryl and Barry
Front to back will be different
Lazer Guy is offline   Reply With Quote
Old 11-14-2008, 09:42 AM   #14495
jag88's Avatar
Originally Posted by Lazer Guy View Post
Hi Darryl and Barry
Lazer Guy = Hara with round eyes !!!!
Hi Russ.
jag88 is offline   Reply With Quote
Old 11-14-2008, 10:11 AM   #14496
But what is the membrane ?
Old 11-14-2008, 10:17 AM   #14497
ShaunMac's Avatar
Rubber bladder on top of the shock.
ShaunMac is offline   Reply With Quote
Old 11-14-2008, 11:24 AM   #14498
but how do i know if its worn out ( the membrane ) or not ?
Old 11-14-2008, 12:00 PM   #14499
ShaunMac's Avatar
You will have a leaky shock with inconsistent rebound.
Old 11-15-2008, 12:56 AM   #14500
What does it do by standing the shocks or laying them down ?
Ive been told that standing them will decrease weight transfer and make the car more responsive . Is it the right thing?
Ive notissed that at the IFMAR 2008 everybody is laying there shocks on the rear and standing them in the front ? Why ?
thanks
Old 11-15-2008, 09:54 AM   #14501
mac853's Avatar
Could somebody tell me if i want to have a full option Cyclone S, so which is the better and easier way: to purchase a Cyclone TC then changed it with a tub lower deck, or just buy a genuine Cyclone S then full modified it?
And somebody could tell me if tub really weighs much more then carbon lower deck?
In the case our org. has created already a new race class, with 1600G and 3100KV(if you prefer BL) then with black sport tuned if BR, so i want understand if Cyclone S with TC parts is worthy or full options Ta05 is better.
Best regards
mac853 is offline   Reply With Quote
Old 11-17-2008, 12:53 AM   #14502
mangoman's Avatar
The tub is a lot heavier than a CF deck, dont remember how much by. Try searching the cyclone s thread.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-17-2008, 01:33 AM   #14503
mac853's Avatar
OK, maybe i don't need to add lead on the tub, thanks.
Could you then somebody tell me if the carbon top deck really match on the tub?
In the case on the HB site, the option parts list is included.
Best regards
Old 11-17-2008, 04:15 AM   #14504
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Best regards
Pretty much all the parts match the tub chassis so you'll be good...
If you look though the Cyclone S thread, they probably got all the answers you're looking for
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-17-2008, 09:27 AM   #14505
mac853's Avatar
Excuse me, there are just very little kind, they convince me as they are just drifters!
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
