Old 11-11-2008, 06:24 AM   #14431
rcarmchl's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Ramyuras View Post
Thanks for the info I rather get the Pro- Spec diff than spend all that $$
on a new kit.
I run the black cyclone with the new diff and am duking it out with 008's all over the place...the cars stacks up up - still very competitive.
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 11-11-2008, 06:55 AM   #14432
Lonestar's Avatar
Interesting discussion on rebound here.
One thing I never understood is how the little force generated by a latex membrane can make such a change once it is added to the stiff springs we are running on the four corners of the cars... when you consider the spring stiffness, that bladder pushes almost nothing... The foams I understand, they suddenly stiffen the suspension big time (closed cells) but the membrane-generated rebound, I just don't get it...
Paul
Lonestar is offline   Reply With Quote
Old 11-11-2008, 08:48 AM   #14433
ShaunMac's Avatar
Anyone with info on the new sway bar system that comes on the TC I was looking back a few page and didn't get any info I am looking for, will the new sway bar fit on the first cyclone the black ver? anyone.
Thank you.
I haven't used the new swaybar mounting hardware, but it will work with the black version of the Cyclone using either the older or newer A-arm design. Only the mounting harware has changed on the TC. The actual swaybars are still the same as other Cyclones.
I have noticed that HB team drivers (Hara, Moore) are still using the older swaybar mounting harware over the newer design. Not sure if there is any real reason for this or not.
ShaunMac is offline   Reply With Quote
Old 11-11-2008, 09:58 AM   #14434
Default gearing queston
I recently purchased my first ever electric car. This being a Hotbodies Cyclone S kit. I bought it to do some winter racing indoors and after the completion of my build I can't wait to see this thing in action. My question though, is since this is my first foray into electric I'm not sure what size pinion gear to use w/ the stock 96 tooth spur. I will be running in a stock 27 turn/17.5 class and I was curious to hear some suggestions. I have been told that it is a medium sized track w/ decent staights and enough turns to keep you busy. All i know is if this electric runs as good as I'm hoping there's gonna be alot of nitro stuff for sale here and on the bay.
rogueldr is offline   Reply With Quote
Old 11-11-2008, 10:11 AM   #14435
Thraex's Avatar
It's because the new ones tend to bind pretty much. You can warm up the ballcups (with a lighter for example), but than the ballcups seem to be pop off quite easily. That's why most of the time the older versions are used.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 11-11-2008, 10:11 AM   #14436
STLNLST's Avatar
Trader Rating: 19 (100%+)
Thank you.
I have it on my black Cyclone. It fits but you will need to cut away about 5mm off the end of the sway bar. You also have to raise the link higher than the 1mm the instructions suggest. This is about as close to a tweak free sway bar system other than the TC5.
once I buy another rear and front bar I will be going back to the old system.
STLNLST is offline   Reply With Quote
Old 11-11-2008, 12:04 PM   #14437
ShaunMac's Avatar
Depends if you are running a 27T or 17.5 motor.
27T CO27 gear 6.5 - 7.0 FDR (with rubber tires) depending on track and your particular motor.
-with a 96T spur you would need between a 33T - 36T pinion.
17.5 needs A LOT more gear. Try down in the 3.5 FDR range. Again, track size, motor brand and batteries all play a role in finding the proper gearing.
-you will need to get a smaller spur to reach the low ratios needed for stock brushless motors. Probably something around 88T spur and some high 50's pinions.
On another note: I have heard the stock C-hubs included with the Cyclone S are rather brittle. You might want to get some of the carbon C-hubs if you break the stock ones. The carbon hubs are the same hubs that come standard on the WCE and TC versions of the Cyclone.
HPI73518 4 degree carbon c-hubs
Old 11-11-2008, 12:12 PM   #14438
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
for 17.5 you're gonna want an 80t spur gear from here...
http://www.precisionracingsystems.com/products/26
and a range of pinions from which i suggest 54-58.
http://www.precisionracingsystems.com/products/7
I run 80/57 in cyclone with an orion 17.5
Originally Posted by Denso View Post
Thanks to those whom have replied. I appreciate it.
I guess I just want to make sure I pick up a a good chassis in the Cyclone S.
I can't afford the TC spec right now, but just want a good competitive car out of the box. I just don't want to pony up the cash for a Cyclone S and then HB release and 2.0 version. That is why I asked if anyone here has any information if a new or revised Cyclone S will be released in the near future.
Any info?
Thanks,
hs
dont worry about that. The regular Cyclone S is doing well enough in sales and such that theres no need to update or re-release it and even so, if an update was released it would not be substantial (as is the story with regular cyclones. The original black one is still competitve and thats HOW many updates later?).
Syber Serulean is offline   Reply With Quote
Old 11-11-2008, 02:07 PM   #14439
[27T CO27 gear 6.5 - 7.0 FDR (with rubber tires) depending on track and your particular motor.
-with a 96T spur you would need between a 33T - 36T pinion.]
I'll be running a Team Orion Core Stock 27T motor w/ Maxamps 6 cell 4600's so you think anywhere between 33 and 36t would be good? I noticed on the Hotbodies site that the RTR comes w/ a 42t pinion and a 27t motor. Also for those of us dumb in the ways of electric what does FDR mean. I have no idea what you mean when you say 6.5-7.0 FDR. And thanks for the heads up w/ the hubs
Old 11-11-2008, 02:23 PM   #14440
STLNLST's Avatar
FDR= FINAL DRIVE RATIO
All motors have a sweet spot to be run at. The FDR is what most run that particular motor at and they may only have to be geared up or down one tooth depending on the track layout.
Old 11-11-2008, 03:58 PM   #14441
Core stock's are weird to gear compared to Trinity motors. I cant help you there.
by the way
spur/pinion X internal drive ratio (should be 2.4375 for the cyclone) = FDR
Old 11-11-2008, 04:16 PM   #14442
rc pete's Avatar
At the 1st Leg of the Western Canadian Indoor Championship Series (www.wcics.ca), I picked up the TQ and win in 19T with the Cyclone (unfortunately, we don't run mod in the series).
The XRay Canada team was out in full force (8 of them in the A-main, and 1 TC5), so it was nice to get the Cyclone dialed in.
For those of you running Rubber tires on Carpet, I'm including my setup. It's pretty close to one of Andy Moore's.
Pete
File Type: pdf 2008-11-09_Cyclone_WCICS_Edmonton_PeterTozser.pdf (327.3 KB, 106 views)
Last edited by rc pete; 11-12-2008 at 09:34 AM. Reason: corrected setup sheet: used spool not one-way
rc pete is offline   Reply With Quote
Old 11-11-2008, 04:36 PM   #14443
STLNLST's Avatar
Pete
Does anyone run a center oneway along with the front??? Just curious to know if that helps the car out any or is it overkill??
Old 11-11-2008, 05:10 PM   #14444
Pete
What an awesome news!
Congrats on your winning of the WCICS!! Great job...
If you have any pics from the event, please send them to me at kasuyah@hpiracing.com I will put those on our web with the report.
Thanks!!
Hi-LowBlow is offline   Reply With Quote
Old 11-11-2008, 06:12 PM   #14445
rc pete's Avatar
Good catch, I was running a spool, not the one way up front. I did try the one way, because traction was good, but the car didn't transition as smoothly. One of the other Cyclone guys was trying a center one-way with the spool up front, but it didn't work out.
But in general, if you were running the front one-way, the center one-way wouldn't do much, since the front wheels are free-wheeling off power anyway. The only case where the center one-way would do something for you would be if you were running a diff or a spool up front. That's my take, but I recall seeing some old Massami Yokomo touring car setups where he did end up using both one-ways, for whatever reason.
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
