Old 11-06-2008, 01:27 PM   #14401
edseb's Avatar
Originally Posted by dannybcaitlyn View Post
Im building my cyclone TC now and im now working on the shocks. Any tips ? How do I bleed these shocks top cap or bottom.
Fill them up with the shock standing vertically, and add a little extra oil so that when you put the bladder it will squish some out. Bladder shocks work different than emulsifying shocks that you see in electric offroad buggies. In bladder shocks you fill them up almost to the top, then work the piston in and out to make sure you didn't trap any air bubbles. You can also use a Ride Shock Pump to vacume out any remaining air, but if you let the bubbles work themselves out you could probably skip that tool. After working the shocks, let them sit vertically for at least 5-10 mintues to let any bubbles work there way to the top and escape. Next, with the shock shaft extended, put the bladder on top without the cap. Press the center part of the bladder down and let the excess oil bleed out the sides till the bladder has a nice seat (yeah it makes a little mess). You then can screw on the top cap. For less rebound you can bleed the oil like before, but push the shock shaft in half way (you can fine tune by pushing the shock shaft more or less in at this step). This will displace more unwanted oil in building and bleed off so rebound from displaced oil will be less when on the track. For more rebound, skip the step, or you can run with foam on top of bladder since kick back will be more aggressive. Measure the rebound when you push the shaft in all the way by checking how far it rebounds. You can do this with calipers. Hope this makes sense.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 11-06-2008, 09:27 PM   #14402
RevXS's Avatar
Has anyone run Jet Alloy front knuckles/C Hubs and rear hubs on there cyclone? Just been looking on RCMushroom at some,need to buy new knuckles and c hubs so just wondering if to buy some alloy ones or not
http://rc-mushroom.com/product_info....ducts_id=12599
http://rc-mushroom.com/product_info....ducts_id=12602
http://rc-mushroom.com/product_info....ducts_id=12614
RevXS is offline   Reply With Quote
Old 11-06-2008, 10:44 PM   #14403
EJ20's Avatar
Originally Posted by rc pete View Post
I went to the 0 from 1.5 (indoor carpet on rubber tires), in order to sharpen the turn in response and reduce mid-corner steering. We run on a bumpy track, and having the front end grab too much mid-corner unsettles the car. You end up with a slight mid-corner push as the steering gets flatter and you have to either drive around that or tune for it.
Thanks RC PETE for your information!
EJ20 is offline   Reply With Quote
Old 11-06-2008, 10:58 PM   #14404
cyclone speed's Avatar
thanks for the tip , my shocks kept leeking but now i will rebuild them like this .
But i dont get what is rebound , should i use it or no ??
cyclone speed is offline   Reply With Quote
Old 11-07-2008, 12:16 AM   #14405
mangoman's Avatar
Dont know exactly what it does for the handling, but rebound is basically when you push the piston into the shock body (without the springs on) they bounce back out cause of the compressed oil inside.
I was told to build the shocks with rebound, i like to build four shocks together with same oil then compare how much each shock rebounds and group them together. I have spare shocks all over the place though so i can build four for the front then four for the rear.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 11-07-2008, 12:51 AM   #14406
Matt Pocknell's Avatar
Rebound is how far/fast the shock shaft extends due to the pressures in the shock, without counting the rebound the spring causes.
For instance, I run 75-100% rebound outdoors to try and generate some responsiveness. Indoors the cars are too responsive, so I run closer to 50% rebound.
Matt.
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 11-07-2008, 03:04 AM   #14407
What pinion/spur combo(64dpi) do people run to get around 3.6fdr which is the aproximate gear ratio for 17.5 on a track I am about to run on. I see that 85spur and 50-53pinion will give the ratio(on TC 2.16 internal) but will the gears mesh? I have tried 78/48 and they are mile apart
kingpops is offline   Reply With Quote
Old 11-07-2008, 03:21 AM   #14408
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Matt
For 64p your looking for pinions in the 50 range. I was looking for something like 84spur with a 53 pinion with 17.5. Go with 48P that's what i did. Heck if you can get the spur i got the rite pinions to go with it if you need.
Also for kambah your after approx a 53-54mm roll out with the 17.5. Ill be testing the 54mm roll out this Sunday and seeing how it goes
Alex Ilievski
*AWESOMATIX * R1 WURKS * PLAIG BEARINGS*
A Ilievski is offline   Reply With Quote
Old 11-07-2008, 09:41 AM   #14409
Matt.
How can i adjust rebound?
By the way , can i make the car more responsive by standing the shocks ?
If the car is too responsive , can it make the rear end slide ?
Old 11-07-2008, 05:45 PM   #14410
Thanks. Thats the kind of info I was looking for. The book doesn't go into much detail.
dannybcaitlyn is offline   Reply With Quote
Old 11-09-2008, 07:29 PM   #14411
thekthai's Avatar
Default any new car kit from HB CYCLONE
pls post some picture of new TC spec or protoype tc
coz im looking tooo..thk alot...
thekthai is offline   Reply With Quote
Old 11-09-2008, 07:51 PM   #14412
Trader Rating: 42 (100%+)
Default cyclone
noob question for a hot bodies cyclone.
I was looking at a used cyclone ( I think Black) version ( I know it's not an S) to run in the VTA class. The current owner hit something and bent a RT front axle, he had to order a new one from Japan ?
Is there any place in the US that sells parts to this model car ?
thanks
miket3 is offline   Reply With Quote
Old 11-09-2008, 08:28 PM   #14413
Scott B's Avatar
Trader Rating: 43 (100%+)
thanks
Tower and Stormers carrys parts.
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 11-10-2008, 04:30 AM   #14414
Trader Rating: 22 (100%+)
If your local shop does not have parts you can always use www.hotbodiesonline.net
-j
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 11-10-2008, 04:43 AM   #14415
shadow102's Avatar
Trader Rating: 21 (96%+)
thanks
Speedtechrc.com I just ordered from them they have a lot of the newer tc parts along with the 3racing and jaad parts
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
