Old 11-03-2008, 12:59 PM   #14386
shadow102's Avatar
Trader Rating: 21 (96%+)
Originally Posted by Anemic_SluG View Post
Anyone try out the adjustible chasis stiffiners for the optional rear deck etc. I am going to be running carpet rubber with my TC and have the kit yet haven't ran them yet. I know on a foam setup stiff is good but with rubber tires is everyone running a high traction asphalt setup?
When I switched to indoors I switched to the wce rear heatsink deck sink
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 11-04-2008, 10:04 AM   #14387
Talking
Hey guys
I have some questions for you all.
I just bought world edition front solid axle(ver.3) for my cyclone.^^
which drive shaft I need for this front solid axle(ver.3)?
There are so many different versions out there. Please could you all help me out?
thanks,
bara1129 is offline   Reply With Quote
Old 11-04-2008, 10:45 AM   #14388
RC MARKET's Avatar
Originally Posted by bara1129 View Post
Hey guys
thanks,
in market drive shaft fit your spool ver.3
RC MARKET is offline   Reply With Quote
Old 11-04-2008, 12:15 PM   #14389
can you tell me any part number for drive shaft fit in front solid axle(ver.3)
Thanks,
Old 11-04-2008, 03:29 PM   #14390
trickd122's Avatar
Default Loose off power !!
Need a little direction here.
I am running the Cyclone Black, I am running 4 degrees droop fr and rear. When off power (no brake) the rear breaks loose. I tried adding more droop in the front same issue.... ANY IDEAS?
trickd122 is offline   Reply With Quote
Old 11-04-2008, 03:33 PM   #14391
61388 purple universal bone should fit if you have universals
61396 black universal bone should fit if you have universals
61378 blue universal bone should fit if you have universals
61095 purple mip cvd bone should fit if you have mip cvds
70710 black universal bone will not work.
bionictony is offline   Reply With Quote
Old 11-04-2008, 03:46 PM   #14392
yyhayyim's Avatar
Trader Rating: 26 (100%+)
"Trick": What set up are you running? What tires?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 11-04-2008, 04:07 PM   #14393
Coldn's Avatar
Send a message via MSN to Coldn
hy,
I have two questions, do you could help me?
whats better in "Cyclone TC" with Brushless?
use pinion and Spur gear 64P or 48P?
and I can use a Lipo Orion 5000 platinium
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 11-04-2008, 04:07 PM   #14394
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
So many reasons why that happens. Check your shock position in front may be to layed down. Could be your tires not glued properly or bind somewhere.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 11-04-2008, 04:25 PM   #14395
shadow102's Avatar
Originally Posted by Coldn View Post
hy,
64p is smoother and gives you more gearing option.
The orion will fit just have to grind the top deck support a little
www.nexusracing.com
www.go-rc.org
Old 11-04-2008, 07:25 PM   #14396
Little_Mike's Avatar
if you really want us to analyze it, put your complete setup on one of the (blank, or filled in you can edit it) setup sheets you can download. then the help will come. See you on-road!
-Mike
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 11-05-2008, 05:31 AM   #14397
Coldn's Avatar
hummmm.. ok thank you very much..
Nanotech 6000mah
Old 11-06-2008, 11:30 AM   #14398
EJ20's Avatar
Hi, I got a question for anybody who know what's the effect if I use 0 degree toe block up front (FF)? Is that only because for less aggressive? Anybody've been tried?
EJ20 is offline   Reply With Quote
Old 11-06-2008, 12:00 PM   #14399
rc pete's Avatar
I went to the 0 from 1.5 (indoor carpet on rubber tires), in order to sharpen the turn in response and reduce mid-corner steering. We run on a bumpy track, and having the front end grab too much mid-corner unsettles the car. You end up with a slight mid-corner push as the steering gets flatter and you have to either drive around that or tune for it.
rc pete is offline   Reply With Quote
Old 11-06-2008, 01:17 PM   #14400
edseb's Avatar
I've tried the aluminum one, carbon fiber one by 3 Racing and the stock one all side by side on medium to high grip asphalt. The other ones take away traction and overall smoothness. The rear end seemed to chatter more and just make it a bit less predictable. I really didn't see any advantage to running the other ones. It wasn't just stiffening up the back, there were a few side affects that weren't very good. If you are looking to try some stuff, I thing there are some other things you can try to achieve your goal without using those. My 2 cents.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
