Hot Bodies Cyclone
Hi, i have just put 18t belts and pulleys inmy cyclone wce and the front belt is a bit tight with the spool bearing holder mark is facing the front of the car and the rear belt is a bit loose with the bearing holder mark facing downwards. Just wondering what is the best position to put these bearing holders in so you get the right amount of tension for the belts.
Registered User
Im building my cyclone TC now and im now working on the shocks. Any tips ? How do I bleed these shocks top cap or bottom.
just put the bladder on top it should bleed it .
Anybody looking a blue brushless motor mount for the cyclone. pm me.
Trader Rating: 23 (100%+)
Anyone try out the adjustible chasis stiffiners for the optional rear deck etc. I am going to be running carpet rubber with my TC and have the kit yet haven't ran them yet. I know on a foam setup stiff is good but with rubber tires is everyone running a high traction asphalt setup?
Hey guys
I have some questions for you all.
I just bought world edition front solid axle(ver.3) for my cyclone.^^
which drive shaft I need for this front solid axle(ver.3)?
There are so many different versions out there. Please could you all help me out?
thanks,
thanks,
in market drive shaft fit your spool ver.3
can you tell me any part number for drive shaft fit in front solid axle(ver.3)
Thanks,
Thanks,
Loose off power !!
Need a little direction here.
I am running the Cyclone Black, I am running 4 degrees droop fr and rear. When off power (no brake) the rear breaks loose. I tried adding more droop in the front same issue.... ANY IDEAS?
61388 purple universal bone should fit if you have universals
61396 black universal bone should fit if you have universals
61378 blue universal bone should fit if you have universals
61095 purple mip cvd bone should fit if you have mip cvds
70710 black universal bone will not work.
