Old 10-29-2008, 09:27 AM   #14356
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Lazer Guy View Post
You guys are funny
It sure would be nice if HB came out with some cover's for the diffs like the Xray diffs have, the jaad ones dont stick to well on the pro spec for me.
They can come out with it.......will we be able to get it locally
STLNLST is offline   Reply With Quote
Old 10-29-2008, 09:31 AM   #14357
STLNLST's Avatar
Originally Posted by shadow102 View Post
That's why I like the fact that xray engraved the numbers into the new springs. I think I am just going to sell off my pro4 springs since I don't use them any more. The 008 springs are more progressive than the linear older springs and just provide a calmer feel to the car
So Xray went with a progressive spring now???? I'll stick with the linear for now.
Old 10-29-2008, 10:48 AM   #14358
cyclone speed's Avatar
Originally Posted by cyclone speed View Post
hi , i went back trought my car to clean it , rebuild it and when it came to shock rebuild , i wanted to rebuild them so i put some oil blah blah blah and when i closed the cap and i was compressing it the shaft came back like normally but then it started leaking even after the fith time i was compressing it so i took of the spring and compressed the shaft but it came back slowly not like in the begining .
Is there a way to fix this please ?
any solution for this probleme ?
Also , you guys have been talking about linear springs and progressive , whats the difference ?
wich one is better , could anyone give me a link to the xray spring that you talk about .
Thanks guys
cyclone speed is offline   Reply With Quote
Old 10-29-2008, 11:06 AM   #14359
shadow102's Avatar
Trader Rating: 21 (96%+)
My mistake they are still linear but they just feel a lot smoother on my car as compared to the hpi and older xray springs.
Cyclone speed here is the link the black xray springs:
http://www.nexusracing.com/product_i...oducts_id=1571
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 10-29-2008, 11:12 AM   #14360
RC MARKET's Avatar
I'm in Thailand saw all TOP Driver is use HPI & A.Hara shock spring for base !
U can saw Tamiya , HB & Kyosho .
Thailand local XRAY driver same change shock mount use HPI spring .
they said spring in market had easy to setup all track !
RC MARKET is offline   Reply With Quote
Old 10-29-2008, 11:34 AM   #14361
STLNLST's Avatar
I may check them out then. I wonder if they offer them in different rates compared to their colored springs. Like will they still offer a 14lbs and a 15lbs in the new style or do some weird in between ones. I guess I'll go do some quick research and see what the deal is. Thanks for the heads up on the new springs being stamped.
Old 10-29-2008, 12:29 PM   #14362
shadow102's Avatar
Check that link I gave it shows where the new springs line up with the old springs
www.nexusracing.com
www.go-rc.org
Old 10-30-2008, 01:49 AM   #14363
Trader Rating: 18 (100%+)
Hi all, i recently got 18t pulleys and belts for my cyclone and wanted to know what transmission ratio this now creates. Also what spur and pinion size would i use for a 6.5t, 17.5t and a 9.5t brushless motor.
If anyone could tell me that would be great.
Rhys.
speed freak is offline   Reply With Quote
Old 10-30-2008, 03:35 AM   #14364
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Internal drive ratio for 18T pulleys is 2.1667. If you are not using a brushless motor mount, max spur 109T. Temp your motor to determine pinion size.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 10-30-2008, 08:33 AM   #14365
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Rhys.
For rubber tires...
For 17.5 start around 4.0 FDR
For 9.5T start around 5.5 FDR
For 6.5 start around 8.5FDR
To find the spur/pinion combination: # spur gear teeth, divided by # pinion gear teeth, multiplied by Cyclone's internal ratio(2.166) = Final drive ratio
Spur
______ X (2.166)
Pinion
for 17.5 you want to gear around 4.0FDR, then a 96 spur with 51 pinion will get you a 4.06, which is close enough.
96
____ = 1.88
51
1.88 X 2.16 = 4.06
You can also visit gearchart website and it will work this out for you: www.gearchart.com
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 10-30-2008, 09:47 AM   #14366
TheCoolCanFanMan's Avatar
Originally Posted by Dan Hughes View Post
Right after taking some time off to go full size car racing im back again for the winter.
Iv dusted off the WCE and it is having its first run back next week. What new parts from the cyclone TC fit the WCE?
Also going lipo do the orion 3800's fit ok?
Dan
Take a peak at this, it may help you in your hour of need
New product, The LWP
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-30-2008, 10:39 AM   #14367
Korey, you have PM
Cheers Malc
Old 10-30-2008, 02:33 PM   #14368
Originally Posted by yyhayyim View Post
For rubber tires...
Spur
______ X (2.166)
Pinion
96
____ = 1.88
51
1.88 X 2.16 = 4.06
Thanks for your help guys.
Old 10-30-2008, 03:05 PM   #14369
jag88's Avatar
anybody know if the TC chassis could be used as a replacement for the Andy Moore edition ? I realize that there are a few extra holes but do all the important ones line up?
Thanks.
jag88 is offline   Reply With Quote
Old 10-30-2008, 03:42 PM   #14370
shadow102's Avatar
Thanks.
Yes and the cell holes will be larger
www.nexusracing.com
www.go-rc.org
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
