Old 10-28-2008, 08:49 AM   #14326
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I tried running without getting the balance back in the car and it was a very bad idea. Its going to be a handful to drive and your going to kill tires on one side. I would just take the time to do it right. You can also buy a box of weight at your local auto parts store for about $30 and share it with your friends. And by a box I mean like 15lbs of weight.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 10-28-2008, 09:15 AM   #14327
Lonestar's Avatar
Well, it happens that at my track no one but one guy (and not the fastest one) runs any lipo plates... and we're a pretty competitive bunch, believe me, with a former vice-world champ and regular Euro top-30 finisher up until a couple of years back.
again - to each his own.... all I'm saying is lipo plates aren't a "must have", just a "nice to have" for some. I'm happily trading a bit of balance for 150g less on my car.
Paul
Lonestar is offline   Reply With Quote
Old 10-28-2008, 10:56 AM   #14328
Default low grip set up?
Hi from england!- i have a feeling this will only apply to the brit cyclone owners, but we race on a very low grip wooden polished floor, and i just wondered if anyone has any set up pointers? i have done the best I can so far, long camber links, shumacher 20 mm mini pins, 20- 30 cwt oil etc, but would like to take the car up a level. i use a novak 8.5 and lipo for the benefits of low maintenance, and I know thats ridiculous for such conditions, and the car is ok, but no more than that. would tightening the belt help straighten the car under hard acceleration? anyone advise on the droop etc? thanks for your help
cpower36 is offline   Reply With Quote
Old 10-28-2008, 03:03 PM   #14329
cyclone speed's Avatar
Hi guys, why do people use stiffer front springs and softer rear springs , what will it do if its the other way round ?
cyclone speed is offline   Reply With Quote
Old 10-28-2008, 04:45 PM   #14330
STLNLST's Avatar
Trader Rating: 19 (100%+)
KOREY????????????????
STLNLST is offline   Reply With Quote
Old 10-28-2008, 06:22 PM   #14331
Korey Harbke's Avatar
If you had harder springs in the rear than the front, the rear inside tire will most likely lift up in the corners. That will drive all the power to the rear inside tire, and not to the outside as well. This will destroy any power being transfered from the car to the ground, reducing corner speed.
Not to mention the car would be really hard to drive. Usually it would be really loose in the rear. It would spin out too easy.
Hope that made sense
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-28-2008, 06:36 PM   #14332
yyhayyim's Avatar
Trader Rating: 26 (100%+)
What's your current set up and what would you like the car to improve on?
Belt tension wont really help with the car jerkin to one side on throttle...seems like your car might be tweaked or something is not lined up or unbalanced.
Is your car balanced left to right?
Make sure you have the equal amount of droop right and left, camber, toe, etc.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 10-28-2008, 08:56 PM   #14333
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
My experience, I had a race that the track condition was so dusty and a bit bumpy. Made the car so loose and almost drifting on turns. Used low weight damping on the rear without stabs and loosened my rear diff on almost to slip. I think once you tighten the belt tension, yes it gets harder acceleration but it can generate twitchyness on corners on power.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 10-29-2008, 01:11 AM   #14334
-Korey
Yep , that makes sense , thanks Korey
Old 10-29-2008, 04:03 AM   #14335
Right after taking some time off to go full size car racing im back again for the winter.
Iv dusted off the WCE and it is having its first run back next week. What new parts from the cyclone TC fit the WCE?
Also going lipo do the orion 3800's fit ok?
Dan
Dan Hughes is offline   Reply With Quote
Old 10-29-2008, 05:02 AM   #14336
Trader Rating: 68 (100%+)
What new parts?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 10-29-2008, 05:52 AM   #14337
shadow102's Avatar
Trader Rating: 21 (96%+)
All the tc parts transfer over to all the other cyclone models except the atc posts. In order to use those you need the tc upper deck and the tc chassis since it has the holes. However the only two parts that the tc has that are worthwhile are the new suspension arms and especially the new rear diff.
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 10-29-2008, 06:26 AM   #14338
Lonestar's Avatar
yup - they drop right in, worst case file a bit of the motor mount where the top deck hooks on. You have to be able to flex the car without binding.
For info, WCE is still just as competitive as TC for 99.9% of us
Paul
Old 10-29-2008, 06:53 AM   #14339
So the new chassis only has battery trays and atc post holes?
Might look into the arms but they dont seem to offer much more, thanks anyway. I didnt really have much problems with the old diff but i might get the pro spec to try.
Paul
I wont bother changing that much by the sounds of things. Just give it a rebuild and get the thumbs back up to speed!
Old 10-29-2008, 06:55 AM   #14340
mac853's Avatar
Paul
As I understand, TC is just replacement of WCE, doesn't mean as its sucessor, just totally step back, some option parts could not included as WCE had.
All WCE users of our town, didn't change for TC, instead of car users of another makes.
mac853 is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
