Old 10-22-2008, 03:59 AM   #14221
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Cyclone Experts,
Anyone knows if the TC diff shims fits in the 3Racing Alu Diff for HB Cyclone (3R-CY-08PU)? Thanks.
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 10-22-2008, 04:26 AM   #14222
não Miguel, esse é a da versão antiga e tens de usar estes HPI72105, tenho cá 4 sacos disso.
ehehehe
jorgesimes is offline   Reply With Quote
Old 10-22-2008, 05:13 AM   #14223
cyclone speed's Avatar
Originally Posted by tomracing View Post
decrease front droop helps for me as a quick solve.
perhaps i make my car move to much but i run 4.5 all round (fronts very loose on the 4.5 gauge but won't fit 5 under it. rears go tight on the 4.5 surface)
edit: mixed up the gauge so changed it to be correct
Hi , im already running 2.5mm droop OVER RIDE height wich is abit low .
Is there anothe way.
Thanks for the reply
cyclone speed is offline   Reply With Quote
Old 10-22-2008, 05:22 AM   #14224
MSB
MSB's Avatar
ehehehe
Obrigado Jorge!
Dessas tenho resmas, ainda do Pro4 e Yokomo. Thanks!
cheers
Miguel S. Braga
Old 10-22-2008, 05:31 AM   #14225
shadow102's Avatar
Trader Rating: 21 (96%+)
Experiment....get some practice time and change the front toe block, try different springs, play with the camber links and vary the droop some. It may even come down to changing your body are you running a speed6?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 10-22-2008, 05:36 AM   #14226
Hi im curently running a mazda6 not speed6.
I have the 1.5 3racing front toeblock.
I have moved from gold spring to pink spring in front.
And i have my front camber links to normal lenght and rear fully extended.
Old 10-22-2008, 05:45 AM   #14227
shadow102's Avatar
The speed 6 will give you more steering. What spring are you running in the rear? I know shortening my camber links made the car more reactive and just increased the on power steering I already had. I am only running 2mm droop over ride height right now too.
www.nexusracing.com
www.go-rc.org
Old 10-22-2008, 07:34 AM   #14228
Hi , im running pink front and silver rear .
i will try shortening camber links , but i extended my links to the max because i run on a low grip track , and by having longer links gave me more rear traction wich i needed.but i will try shorter links.
What im looking for is more onpower steering but not at full speed, only at half speed.
Old 10-22-2008, 08:06 AM   #14229
shadow102's Avatar
I ran low grip this past summer. Change your springs and try silver front blue rear. I even went to the gold xray springs in the rear which made my rear grip better. Are you running sway bars?
www.nexusracing.com
www.go-rc.org
Old 10-22-2008, 08:11 AM   #14230
im running 1.4mm roll bar all round.
But if i go on softer rear spring , wouldnt it decrease on power steering.
could you pm me your setup on a low grip track , was it a open or medium track.
Old 10-22-2008, 08:11 AM   #14231
Does anybody a hobbyshop has this car in stock 1/12
metheny is offline   Reply With Quote
Old 10-22-2008, 08:23 AM   #14232
You can try antisquat, but if you run a low traction track you might have trouble with oversteering.
Itchy is offline   Reply With Quote
Old 10-22-2008, 08:53 AM   #14233
Hi , i already had probleme with oversteer , thats wy i went from 2 mm to1mm under rear camber link.
Old 10-22-2008, 09:11 AM   #14234
rcarmchl's Avatar
Trader Rating: 15 (100%+)
stormer hobbies has it for 209.95
Blizzard Concepts ~Big-Dog Graphics
Cyclone ~ Orion ~ LRP Sphere ~ S9550
M03 ~ Orion ~ LRP QC3 ~ S9550
RC18R ~ Castle Creations ~ Hi-tec
Slash ~ 9550 ~ SMC Power
8ight-T~9550~V-Spec
rcarmchl is offline   Reply With Quote
Old 10-22-2008, 02:01 PM   #14235
TheCoolCanFanMan's Avatar
Hi all,
Since here we look to be changing to lipo, wich lipo fit to the car without any dremel help?
Thanks in advance.
Hi
We have this in production now, it will be on sale on www.coolcanfan.co.uk very soon, but if you want one, just pm me please.
The LWP is made from 1.5 stainless steel, and weighs approximately 95/100 grams, and is held in place by 2xm3 screws utilizing the 2 holes that are down the centre of the WCE, TC and 008 chassis. A number of lead weights can be adhered to the base of the plate, utilizing the cell slots, I suggest you remove the double sided tape from them, and key the surface of the weight, as well as the LWP, and degrease the surfaces before gluing them to the LWP.
The LWP will have a carbon fibre effect covering which you can apply if you wish, and has a lip on the outside edge, to help prevent the lipo from coming out of the car. Also a piece of sticky back foam, can be used on the LWP towards the left of the lipo, to help prevent the lipo from moving towards the middle of the car. A piece of foam sits just in front of the the lipo, and rests against the front bulk head, whilst the back of the lipo rests against the rear bulkhead, this will help the lipo from moving forward, so as not to unsettle the car. On the 008, the battery strap can be used, or remove the strap, and leave the posts in place, and place a piece of foam in between the lipo and post to help the inertia affect.
The LWP kit will comprise of
1) LWP will be made of 1.5mm brush stainless steel, weighing approx 95 grams
2) 2x3m fixing screws
3) A strip of sticky back foam, to be placed on the opposite side of the lipo, as a restraint.
4) A foam block retainer, for front/rear of the lipo
5) A piece of carbon fibre effect covering for the LWP if you would like to cover the brushed stainless steel.
6) A piece of carbon fibre effect covering for the base of the Orion lipo, once the noduals have been removed, so as to tidy the base of the lipo
This LPW version, will accept Orion 3200 3600 3800 and Nosram 5300 28c to date, as other lipos come along, we will let you know what ones will fit.
This LWP can be used on the WCE, TC, and X-ray008 as there are extra fixing holes in the LWP for each model, you just pick the holes that suit your car.
Further LWP will be available soon for all popular models.
Cheers THECANMAN
Hot Bodies Cyclone-tc-clone-lipo-plate-003.jpg   Hot Bodies Cyclone-tc-clone-lipo-plate-004.jpg   Hot Bodies Cyclone-tc-clone-lipo-plate-006.jpg   Hot Bodies Cyclone-tc-clone-lipo-plate-010.jpg   Hot Bodies Cyclone-tc-clone-lipo-plate-014.jpg
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
