Old 10-17-2008, 01:35 PM   #14176
ShaunMac's Avatar
Originally Posted by cyclone speed View Post
But for the moment i have everything for the pro diff execpte the screw , i tries the originel screw on the pro diff and its too short , is it normal?
Yes, that is normal. The old diff screw was M2 x 25mm. The new diff screw is M2.6 x 28mm.
Look for HB part #67725 - Pro-Spec diff screw set
ShaunMac is offline   Reply With Quote
Old 10-17-2008, 02:44 PM   #14177
RC MARKET's Avatar
Yes !
RC MARKET is offline   Reply With Quote
Old 10-17-2008, 04:21 PM   #14178
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Originally Posted by shadow102 View Post
The extra 1.7mm just fits further into the drive cup if you run a front spool there is no problem. With the extra length on the rear it may contact the diff nut...but why you would need these in the rear is beyond me
maybe RC MARKET can test fit the Xray ECS driveaxles in his Cyclone. If he does and puts a note on the ECS page when its up, im sure EVEN MORE would sell as i know plenty of Cyclone owners would like something this....
Syber Serulean is offline   Reply With Quote
Old 10-17-2008, 11:47 PM   #14179
cyclone speed's Avatar
Hi , ive got another question.
Could you guys tell me how to have abit more on power steering , not full speed steering but half speed on throtle steering.
Like more shims under rear camber link ( lower RC) but having more shims will make my rear end a bit loose .so is there other ways like
less droop i have 2.5mm front droop
or staighter rear shocks or any thing that could help me without affecting alot the rear end because if i put more shims under rear camber link , it will increase onpower steering but it will also decrease rear grip , and when i will go in chicanes my rear end will be loose.
So could you tell me everything that i could do to have abit more on power steering.
Thanks guys
cyclone speed is offline   Reply With Quote
Old 10-18-2008, 07:54 AM   #14180
trickd122's Avatar
Default Fit
I have the cyclone HB (black)
What Lipo packs fit best and has the best performance.
I will be running a 10.5. speaking of which.
Novak 10.5 with the blue ring or the orion Vortex 10.5 please post ANY experiences. I will be using the LRP sphere TC.
trickd122 is offline   Reply With Quote
Old 10-18-2008, 10:51 AM   #14181
STLNLST's Avatar
Trader Rating: 19 (100%+)
without shaving your bulk heads the best lipo pack that will fit is the SMC 4000. As far as motors go I'd go with the Novak. No one seems to really be running the Orion motors in the spec classes right now.
STLNLST is offline   Reply With Quote
Old 10-18-2008, 11:35 AM   #14182
Thanks guys
Advice?
Old 10-18-2008, 11:35 AM   #14183
RC MARKET's Avatar
Yes will import XRAY this new parts to test in cyclone !
Old 10-18-2008, 11:40 AM   #14184
Thank you >>>> That will be great.
Lazer Guy is offline   Reply With Quote
Old 10-18-2008, 12:28 PM   #14185
Much appreciated!!
and for lipos in the Cyclone...
ive used Yeah Racing 3200s and 4000s in there with no problems as well as Orion 3400s and 3600s.
Old 10-18-2008, 02:20 PM   #14186
LOSI123's Avatar
Trader Rating: 63 (100%+)
Some one told me that having 2mm acerman spacers on the servo saver will have more agressive steering than having 4mm of spacers, & then some one told me the oposite is true????
Can some one more knowledgable please confirm which is true?
LOSI123 is offline   Reply With Quote
Old 10-18-2008, 02:55 PM   #14187
trickd122's Avatar
Default Thanks
Thank you for your answers
Just One addition question what heat sink can I use on the motor.
Old 10-18-2008, 04:38 PM   #14188
RC MARKET's Avatar
Much appreciated!!
I'm not have use other HK brand name ,
because this factory had contact with me & OEM to many co.
but many CO. had mark up mah & Discharge C Rate ,
so need take care , always over C to charge ...
& life is shorter than Orion .
Old 10-18-2008, 04:39 PM   #14189
yyhayyim's Avatar
Trader Rating: 26 (100%+)
with 10.5, a simple 3Racing heatsink will do...any of these should be fine...tower hobbies also carries them.
http://www.nexusracing.com/index.php...5938da95c5928d
As far as Lipo's are concerned...SMC5000 and Trackpower 4900 25C packs are great...
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 10-18-2008, 04:40 PM   #14190
RC MARKET's Avatar
2mm is lose some agressive !
your steering need more turn ,
but some layout need to use
& find your driver style to setup !
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
