Old 10-13-2008, 11:09 PM   #14116
vazzo's Avatar
Trader Rating: 100 (100%+)
Has anyone had problems with the inside of the front belt touching the bottom of the servo horn on the TC?
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 10-13-2008, 11:24 PM   #14117
EJ20's Avatar
I had that issue before! Try to shim the center pulley and what I also did is move the spacer on the belt tensioner ( top deck ) inside, close to the tension post and put that two flange bearing together and look again! Make sure it won't over too much on the other side!
EJ20 is offline   Reply With Quote
Old 10-14-2008, 04:44 AM   #14118
Trader Rating: 21 (100%+)
Originally Posted by Syber Serulean View Post
I have to buy maybe 2 or 3 servos pretty soon and $85 or $100 servos are out of this college student's budget lol...i liked another guy's suggestion but then my brother found this...what do you guys think?
http://www.hobbypeople.net/gallery/440702.asp
metal gears, ball bearings, .10/4.8v and .08/6.0v speeds for that price? zomg! I think its worth a shot...cant really disappoint at $30 though right? (of course id just buy one to start with and test it out to see if i liked it)
I currently have a JR 590m servo in my cyclone and i race 6cell/7.4 lipo on asphalt parking lot tracks (my 2wd buggy has a hitec 645mg servo in it as well). Anyways, the torque ratings between the two servos are nearly identical (the 590 and the cirrus i mean). Would you say this is a good buy for the money or should i look for something with more torque? The JR servo i have has served me well...i can usually place top 5 in sportsman at my local races and damn is the competition stiff! Lemme know...i kinda wanna give this a try but i dont want to throw my money away buying it.
Try looking at the Futaba 3305.You might like it.About 30-35.00.M
lotus1 is offline   Reply With Quote
Old 10-14-2008, 09:11 AM   #14119
was running at a club meet on sunday, was quite warm and running sorex 32s and round corners i am slowing down alot just to get around corners because of the amount of understeer i have and the tyres was squeeling alot. can anyone help i am basically running the andy moore base tarmac setup?
jordan.norwood@ is offline   Reply With Quote
Old 10-14-2008, 09:14 AM   #14120
mangoman's Avatar
Yeah ive found that before, i dont think it was rubbing but i was worried about it, so I trimmed the corner off the bottom of the servo horn.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-14-2008, 10:02 AM   #14121
"i am basically running the andy moore base tarmac setup?"
Jordan write down your full set up and i will have a look
blazer2 is offline   Reply With Quote
Old 10-14-2008, 10:34 AM   #14122
heres the setup:
http://www.hbeurope.com/pdfs/setups/...rmac_setup.pdf
Old 10-14-2008, 12:17 PM   #14123
cyclone speed's Avatar
Hi , i have discussed this alot with Korey and he told me to go to 1mm shim under front toe block and keep 1.5 under rear toe block , and it gave me more steering .Id recomend you to try this.
Also if its a low grip try to run 2mm under front camber link and 1mm under rear camber link , try to have 1mm difference between front and rear.It helped alot because i hade my rear end a litle loose but know its fixed.
try and put the 1.5 front toe block it would help abit with steering in the midle and exit.
Most important is are you running the pink spring.I used to have gold in front but know i have pink and MY GOD alot more steering.
So i would first try 1mm under front toe block , then change to pink spring and then move to 1.5 toe block and finally try 1mm difference between front and rear camber links.
Hope that helps
cyclone speed is offline   Reply With Quote
Old 10-14-2008, 03:32 PM   #14124
you guys seen these?
http://forums.radiocontrolzone.com/s...d.php?t=251469
What are the chances these fit on the cyclone? Anyone got any measurements?
Copy of Losi's front LVD design. Didn't Losi patent that idea? Hmmm...
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-14-2008, 03:37 PM   #14125
So, of the setups posted on http://www.petitrc.com/view_news.php?id=4553
should I start with the Phil Chambers Starting Carpet setup, or the Moore Standard Carpet setup. Going to be running 13.5 Rubber TC, using Speedrex 28s, on a high grip carpet track. Also, going to be using a front one-way, not a spool.
Old 10-14-2008, 04:56 PM   #14126
TheCoolCanFanMan's Avatar
You can't patent an idea, you can only patent the product itself, so any small change, no matter how small, it then doesn't interfere with the patent
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 10-14-2008, 07:21 PM   #14127
gentleman81's Avatar
ok, im looking for a good elec car.
this one is definately in my price range.
give me a few pros and cons between this car and the comp?
xray
tamiya
AE?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-14-2008, 07:36 PM   #14128
and 4 models?
Old 10-14-2008, 10:40 PM   #14129
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
doesnt really answer my question though...
Syber Serulean is offline   Reply With Quote
Old 10-15-2008, 12:15 AM   #14130
dontfeelcold's Avatar
Originally Posted by dontfeelcold View Post
Question for all cyclone owners.
1) How much steering lock do you run on your radios? ie maximum steering EPA or dual rate setting.
anyone???
dontfeelcold is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
