Old 10-06-2008, 01:05 AM   #14071
LOSI123's Avatar
Trader Rating: 63 (100%+)
Help needed
I have just installed the HB sway bar stopers to stop sideways movment of sway bars, now they rub/jam on the front pulley.
I have the 18t pulleys with the diff holders pointing straight down.
any idea's on how to fix this problem?
LOSI123 is offline   Reply With Quote
Old 10-06-2008, 03:44 AM   #14072
Stew Noble's Avatar
You need to use the standard plastic roll-bar guides, other manufacturers alloy ones sit the bar too close to the pulley to use the stoppers.
// S N F //
Stew Noble is offline   Reply With Quote
Old 10-06-2008, 01:49 PM   #14073
Originally Posted by Dan87 View Post
hey
i just oreded one of these new cyclone TC could any one tell me if the trak power 5400 lipo fit
cheers
Yes it will fit but you have to take 1.5mm off the arched brace over the battery, so I guess you could say it will not fit without doing that.
Lazer Guy is offline   Reply With Quote
Old 10-06-2008, 02:02 PM   #14074
RC MARKET's Avatar
Originally Posted by ASM View Post
Anyone have the three-hole piston part number handy?
http://rcmarket.com.hk/product_info....oducts_id=3472
RC MARKET is offline   Reply With Quote
Old 10-06-2008, 02:03 PM   #14075
RC MARKET's Avatar
hey
cheers
I'm think Orion 30C bester , because had true 30C discharge
Old 10-06-2008, 02:56 PM   #14076
LOSI123's Avatar
Thanks for that, yes i went back to the plastic ones & its all fixed
Old 10-08-2008, 10:49 AM   #14077
lethal19's Avatar
Is the Cyclone S kit a good kit for racing? and what what be needed to up grade it to running with the bigger name car brands?
lethal19 is offline   Reply With Quote
Old 10-08-2008, 11:11 AM   #14078
cyclone speed's Avatar
if you are going to run as a begining yes its a superb great kit for starting, beacause you can adjust everything like the WCE edition and the only difference between the WCE edition and the cyclone S id that the WCE has more aloy the the S version .Yes i would recomend it for a start
cyclone speed is offline   Reply With Quote
Old 10-08-2008, 11:25 AM   #14079
lethal19's Avatar
can you up grade it to the WCE? where is the cheapest place to get the kit?
Old 10-08-2008, 11:34 AM   #14080
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
yeah you can eventually upgrade it over to the WCE but dont buy the S thinking its more cost effective to just upgrade as fast as you can. See how competitive you are with it first. If you're gonna be racing on asphalt, i suggest getting an upgraded center pulley, the Ver.3 spool for the front, tires that work best on your local track, good electronics, and metal outdrives (i hear the stock ones wear out quick if you run anything hotter than a 27t). Im sure you'll be able to be plenty competitive at that point. Move on with any upgrades you want from there (i would suggest the shocks first i think).
Syber Serulean is offline   Reply With Quote
Old 10-08-2008, 11:48 AM   #14081
yes you can , you can getv the carbon deck , chassis , shock tower , alu bulkheads .
i know that i get most of my parts like a new chassis from www.rcmarket.co.hk
wich is a very good site.
Old 10-08-2008, 11:54 AM   #14082
shadow102's Avatar
Trader Rating: 21 (96%+)
First and foremost upgrade to the s should be the carbon c-hubs they are extremly weak on the stock car. If you do pick one up I have all the silver carbon fiber pieces except the chassis for sale
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 10-08-2008, 12:54 PM   #14083
andyh's Avatar
Default ..TC shipment fresh off the boat
..TC shipment fresh off the boat (plane...)
andyh is offline   Reply With Quote
Old 10-08-2008, 01:10 PM   #14084
KHoff7's Avatar
Woo finally, early October instead of the supposed early September.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 10-08-2008, 02:43 PM   #14085
LOSI123's Avatar
Does anyone make steel rear outdrives for the cyclone wce?
Or any that do not wear as fast as the alloy.
Running Modified
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
