Old 10-04-2008, 07:07 PM   #14026
STLNLST's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Verndog View Post
Thank you for the pic. That could possibly interfere with the dowel pin chassis stop I'm using. I would have to press the dowel to no taller then the thin 2mm chassis, or risk a unhappy customer that is running an older servo. Hmmmm ...there are people really using those even though they hang off the chassis that far? I better move the holes.
I'm only running this servo for a quick 2nd as I'm getting rid of all my futaba crap and going back to all KO stuff. Even though it's big there are still some guys running the larger servo's.
STLNLST is offline   Reply With Quote
Old 10-04-2008, 07:13 PM   #14027
STLNLST's Avatar
Originally Posted by mangoman View Post
The picture from above with the www.teamorion.com on it to me looks wrong. The servo posts are meant to be mounted upright not lieing flat.
Although what is a Cyclone tweak / setup plate? Doesnt have hole on the front for the bumper either?
My mounts have always been laid down. If you look at my pic of the servo mounted in the car the servo would be hanging way off the side if I were to use a standing mount.
Old 10-04-2008, 08:08 PM   #14028
Well, 2nd week of running USVTA with my cyclone, and my second broken diff bolt. First week was the rear diff, and the bolt snapped off right at the head of the bolt. This week, the front diff, and it broke off in the T nut. Is this a known weakness? How do I fix it? I can't keep breaking diff bolts one a week. I mean, really, its a 21.5 motor, I can't be overpowering the diff bolts. Already ordered 2 of the TiNi coated diff bolts from Stormer, I hope they are stronger.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 10-04-2008, 08:34 PM   #14029
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Futaba crap? LOL What happened?
I love my futaba servos. But I have to agree I love my KO servos for sure!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-04-2008, 08:47 PM   #14030
shadow102's Avatar
Trader Rating: 21 (96%+)
Yes the cyclone diff bolt is a known weekness. A good fix is to go with the larger screw from associated or switch to the new pro spec diff. A large problem is your diffs are probably set too tight. Also switch to a spool in the front running usvta the car will run better
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 10-04-2008, 11:21 PM   #14031
STLNLST's Avatar
Didn't really care for the feel of the 3PK but hey I'll live....but it was their terrible and inconsistent customer service that made me walk away from ALL of their porducts. I'll fill you in at the track sometime. It's been more than twice for me.
Old 10-04-2008, 11:31 PM   #14032
That stinks. I was well taken care of when i sent my servo in. Took a whole 4 days, to ship it there, fix it, and get it back. All for free.
Cyclone still treating you well? Lol you go through alot of cars!
Old 10-04-2008, 11:43 PM   #14033
STLNLST's Avatar
Still with the Cyclone. It's been a great car and is easy to drive. I will stick with it so long as RCMARKET stays in business.
Old 10-04-2008, 11:48 PM   #14034
You running 13.5. or mod?
Old 10-05-2008, 12:02 AM   #14035
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by tomracing View Post
verndog
for the plate did you also find that the TCspec chassis plate is wider then the regular cyclone?
i measured mine at
moorespeed 4.222"
TC spec 4.292"
also the servo mounts on the TC spec are about .106" further forward all other holes line up nicely
i took some pictures send me your email adres and i will show you.
it is just the centre (widest part) that has a difference the front and rear parts are equal again.
i think you can solve the difference by two sets of dowels one with overlap one straight set perhaps?
Too late...just got thru putting in a 15 hour day and got this run completed.
What is the difference between these 2 chassis?? The one I used is a newer Cyclone with the battery tabs that snap into slots. I compared it to another Cyclone chassis that Mike had and the chassis profile matched. I dont locate on the "width" of the chassis, I locate on the angles coming off the width seen below. Also, there is a bit of room in the thru holes and a visual guide profile to line up to. ...Checked the chassis I layed out. Its 4.305 wide so it must be the TC, so this should fit both...I hope.
I'll post pics tomarrow....there are a buttload of holes on this model...49 to be exact (including tapped clamp holes). I'll keep the price the same even though labor costs are 20% higher with all the mount locations.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-05-2008, 12:06 AM   #14036
STLNLST's Avatar
13.5 from here on out. I don't run mod anymore.
Old 10-05-2008, 12:12 AM   #14037
STLNLST's Avatar
Looks good bro. Go get some sleep now
Old 10-05-2008, 12:30 AM   #14038
cyclone speed's Avatar
guys ive got another probleme .
When my car steers , not on the ground , im holding it in my hands , if i put the throtle on when my car steers at full steering , it makes a noise like if it was glitching (but it dosnt glitch) but when i steer but not at full steering it doesnt make that noise.
i.e:
when i steer to the left or right at 50% it doesnt make that noise , 60% no noise 70% no noise , but 80 , 90 and 100 % it makes that funny noise ,
The noise is like if a car was glitching or when two gears dont mesh.
Do any of you have this probleme .
Thanks for any help
cyclone speed is offline   Reply With Quote
Old 10-05-2008, 12:35 AM   #14039
Korey Harbke's Avatar
Thats the universal joints binding up a little bit I think, which is totally normal. You notice is a lot more when the car is off the ground. Just turn down your steering endpoints a bit and you should be fine.
Vern- That thing looks really cool
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 10-05-2008, 01:05 AM   #14040
Hey Korey
I test last night new things for my TC (high grip carpet with rubbertires) and it seems to be worked well. I lowered rollcenter 1.5mm and shorter front link and also chance front pivot block 0 degree so it cooled down front a lot. I was pleased about those changes. Now i`ll test next shockoils and droops.
Now I drove AE50wt front and 40wt rear and i might test thinner oils like 40/30wt with gold/silver springs
How you measured droops? I measured them like wheels off and lay car on the table and take the hight on the top of the axle
I use front 26mm and rear 24mm droops
Racingfactory.fi -> GM - LRP - Futaba - Tamiya Mini M03 - Tamiya 415MSX MRE - Tamiya 416 WE
Cruisaaja is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
