Hot Bodies Cyclone
Original and a good price too
Ive looked at them a few times and thought of getting them for spares
You still need the upper bulkheads too, but then you can get the new ones which are stronger.
thanks
Hi guys i would like to ask a question but its off topic , i posted a thread of my probleme but got no help so i was going to ask you guys since you have been very helpfull to me.
I have a Gemini 2 41mhz transmitter.I know there is the 27mhz , 40mhz , and the 41mhz versions (that i have).Because i race in the uk 41mhz crystals are illegel only 40mhz are legal, so i was wondering if i could use a 40mhz crystal on my 41mhz version.
Thanks in advance, sorry for the off topic question.
My understanding is that receivers/transmitters are effectively calibrated/tuned (whatever) to the particular bandwidth and that you cant use crystals from a different bandwidth.
If 41Mhz is a different band then yes unless the transmitter has a replaceable module like a higher end 3PK.
Im not familiar with a 41MHz band. I think the 40MHz band does actually stop right at 41MHz so it would mean that you'd have to get a new transmitter/receiver. But you should probably check with the manufacturer or person you bought the system off.
If you have to get a new transmitter and are serious about RC, think about saving up and getting a 2.4GHz system. Take your time researching the product, but generally speaking you pay for what you get.
ok thanks guys i will search to know.
Thanks guys , and sorry for the off topic question.
If 40Mhz crystals do work, i suspect you may have issues with glitching, so keep an eye out for strange things....
Hara was ready JMRCA
changed use 4PK 2.4G
& keep use New Vortex 08 motor with new type magnet armature
but used old upper bulkhead , upper deck ...
