Old 09-17-2008, 05:58 AM   #13861
RC MARKET's Avatar
Originally Posted by tomracing View Post
sorry hara was not in the european championships and I also do not have the ETS setup from andernach
Thanks !
RC MARKET is offline   Reply With Quote
Old 09-17-2008, 07:23 AM   #13862
Dorigecko's Avatar
Send a message via MSN to Dorigecko
Originally Posted by k_bojar View Post
the ones supporting the axels are 5x10x4mm (same as the cyclone)
the rear diffs ones are 10x15x4mm
it uses the same size bearings as the regular cyclone
i don't have a regular cyclone either.
Dorigecko is offline   Reply With Quote
Old 09-17-2008, 07:28 AM   #13863
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Just an fyi the Losi Eight uses a 10x15x4mm in the clutch bell incase you get in a bind.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 09-17-2008, 01:33 PM   #13864
On a black edition Cyclone, is it worth getting the 18T center pulleys and different belts, to change the pulley ratio to 2.1666? For USVTA usage.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 09-17-2008, 01:58 PM   #13865
shadow102's Avatar
Trader Rating: 21 (96%+)
What usvta combo do you plan on going with? For the 21.5 and 27t options you will be fine with the 16t pulleys. For the 17.5 I would suggest getting the pulleys so you don't need a rlly small spur or rly big pinion
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 09-17-2008, 02:33 PM   #13866
21.5/lipo. I know back in the Xray T1 days, they came out with a different set of diff/center pulleys that lowered the ratio from like 2.22 to 1.77, and it made the cars faster. (Changes in the belt speed and efficiency of the drivetrain) Might have to try it eventually and see if it makes the car faster or not. Also opens up the possibilty of overdriving the front wheels with the front spool
Old 09-17-2008, 04:17 PM   #13867
tim fry's Avatar
whats the best spur gears to use for 13.5 I need to run at around 4.5 and for 10.5 I need to get to around 5.4
tim fry is offline   Reply With Quote
Old 09-17-2008, 04:36 PM   #13868
KHoff7's Avatar
I like a 91 for 13.5 and pinions in the 50 range.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-18-2008, 03:38 PM   #13869
Trader Rating: 21 (100%+)
Default MIP Cvd's
Upgrading my black car.Bought the WCE MIP Cvd's.They don't fit the one way in the front.Too fat.Anyone have a part number for the newer(I assume) front oneway? Or parts needed to get this to work? Maybe just the outdrives?Thanks,Mario.
lotus1 is offline   Reply With Quote
Old 09-18-2008, 03:44 PM   #13870
Trader Rating: 62 (100%+)
outdrive #HB61397
oneway # HB61323
N.W Hobbies
M.Pease
The Wease is offline   Reply With Quote
Old 09-18-2008, 07:31 PM   #13871
tenpins77's Avatar
Send a message via AIM to tenpins77
hey anyone have some shots of how they are mouting lipos in their cyclones? i cant mount the wires in the front because the topdeck is in the way looks like im gonna have to run the wires to the rear of the car
tenpins77 is offline   Reply With Quote
Old 09-18-2008, 07:51 PM   #13872
shadow102's Avatar
What kind of lipo are you using. Lipo's like the orions that use bullet connectors are easy to mount...lipo's with built in wiring like the core rc ones require a little bit of finesse
www.nexusracing.com
www.go-rc.org
Old 09-18-2008, 07:54 PM   #13873
jag88's Avatar
88 spur, 46/47 pinion.
Rubber.
jag88 is offline   Reply With Quote
Old 09-18-2008, 07:57 PM   #13874
Default ...................
Originally Posted by The Wease View Post
outdrive #HB61397
oneway # HB61323
Thanks.Mario.
Old 09-18-2008, 08:00 PM   #13875
tenpins77's Avatar
their new trinity 3800's, pratically like the new orion 3800's with bullet? i just though it was strange that i could only connect them in the rear of the car
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
