Old 09-10-2008, 02:31 PM   #13786
Thank you yyhayyim & STLNLST
I'm using a 3.5 chassis and I have 22.5mm of room now. The SMC 5000 is 24.5. If I take 2mm off the tab over the lipo there will only be 2.5 left of the tab, I thought that might be somewhat on the thin side
Thanks again guys
Lazer Guy is offline   Reply With Quote
Old 09-10-2008, 02:49 PM   #13787
STLNLST's Avatar
Trader Rating: 19 (100%+)
Thanks again guys
Running the thicker 3.5 chassis will also take away a little room that you gave to work with. Yo lose an extr 1mm to work with compared to what I had.
STLNLST is offline   Reply With Quote
Old 09-10-2008, 03:27 PM   #13788
Trader Rating: 17 (100%+)
Huh?????
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-10-2008, 03:30 PM   #13789
KHoff7's Avatar
Originally Posted by Advil View Post
Huh?????
He is saying that he is running the normal 2.5 mm chassis. The other guy asking the question has a 3.5 mm chassis. The 1mm difference between the two is what raises the battery sitting on the chassis by 1 mm.
Rubber chassis = 2.5mm
Foam chassis = 3.5mm
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-10-2008, 04:12 PM   #13790
shadow102's Avatar
Trader Rating: 21 (96%+)
Huh?????
I agree. The bulkhead sits on top of the chassis so unless I am thinking wrong the extra 1mm shouldn't matter since everything on the chassis sits 1mm higher
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 09-10-2008, 04:17 PM   #13791
KHoff7's Avatar
They are milled down at the bulkhead mounting points (at least on my foam chassis and all the other chassis I have seen).
Karl Hoffmeister
Old 09-10-2008, 04:42 PM   #13792
shadow102's Avatar
Ahh ok haven't seen a carpet chassis yet.
www.nexusracing.com
www.go-rc.org
Old 09-10-2008, 04:43 PM   #13793
STLNLST's Avatar
The chassis is thicker yes but if you look ata 3.5 compared to a 2.5 you will see that it's milled at all of the bulk heads to keep the roll centers the same as the 2.5 chassis
Thanks for explaining this. It totally slipped my mind
Old 09-10-2008, 04:55 PM   #13794
Yeah, I didn't know that the chassis was milled to lower the bulkheads. I have only seen that on the Corally 4mm chassis.
Old 09-10-2008, 10:45 PM   #13795
cyclone speed's Avatar
hi guys what difference does it make to have a thicker chasis like 4mm or 3.5mm
instead of having a thiner chasis like 2.5mm or 2mm
thanks guys
cyclone speed is offline   Reply With Quote
Old 09-11-2008, 12:19 AM   #13796
Korey Harbke's Avatar
It will isolate all the flex/movement only to the suspension. The suspension will be doing all the work. Usually the car will be more responsive, yet less forgiving to setup changes.
Typically we save thicker chassis to higher grip conditions as it lets the car roll through the corner faster as they produce a little less grip with the thicker chassis.
On asphalt, hot or lower traction conditions the car benefits from a little flex in the chassis. It will provide more overall grip, and make the car a little more forgiving in setup.
Hope that helps
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-11-2008, 11:53 AM   #13797
mangoman's Avatar
Originally Posted by vassago View Post
-The steering turnbuckles hit the pivot block when trying to steer.
It is a good idea to dremel back part of the block, but when you are testing is the car on the ground and fully weighted.
The turnbuckles will have more clearance when the car is properly weighted down.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 09-11-2008, 03:18 PM   #13798
How durable is the Cyclone S Sport TC? Wanting to put together a Vintage Transam car, without spending $400+ on a car. What are the major weak spots that need to be upgraded with better Cyclone TC parts or aluminum aftermarket parts?
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 09-11-2008, 03:32 PM   #13799
RC MARKET's Avatar
I'm think you want use how many money upgrade to TC , or upgrade some TC parts !
RC MARKET is offline   Reply With Quote
Old 09-11-2008, 03:39 PM   #13800
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Stealth, I saw one of the original black cyclones for sale used on the forum for 200 shipped with parts, and it had the bmi chassis too. I would maybe check it out.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
