Old 09-06-2008, 01:33 AM   #13741
Originally Posted by B18C Turbo View Post
im so glad i sold my last cyclone, goodbye HB and your lack of support.
Dude and you are looking for a yokomo Sam? What do you expect for support there? Call them up and they'll say "Oh, put pvc tires and drift"
Tell you what. You buy a rubber car that will have parts availability at RCE and I will run rubber with you with the same car. Just stop buying cars with no support at your local track. (HB,yokomo, any given foreign car that isn't a corally)
JoelV is offline   Reply With Quote
Old 09-06-2008, 01:49 AM   #13742
Aid1970's Avatar
So guys is the TC a better performer than the Andy Moore cyclone Just want to know about performance not bling
Aid1970 is offline   Reply With Quote
Old 09-06-2008, 04:51 AM   #13743
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Originally Posted by Advil View Post
Hey Bro, what can I say....E.J. is DA MAN!!! I am hooked up with the needed parts for this weekend. My setup should be DIALED...for everyone else it is CURTAINS!!!!! HAHAHAHAHAHAHAHAHAAAAAA
Unless someone fast shows up.....LOL
s
Hey Art...how u been bud. Hope all is well.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 09-06-2008, 10:49 AM   #13744
SammyZ's Avatar
Trader Rating: 138 (100%+)
hah! JoelV stock IIC r/c champion
SammyZ is offline   Reply With Quote
Old 09-07-2008, 11:07 AM   #13745
tenpins77's Avatar
Send a message via AIM to tenpins77
Hey guys, not sureif this was answered in one of the 406 post on this thread already, but thats just alot to go through,
Anyway, what do you guys reccomend spur/pion gear wise for the following motor classes with this car.
13.5/ currently i have a 47/88 and i think im undergeard
10.5?
3.5 /6.5?
thanks
tim
tenpins77 is offline   Reply With Quote
Old 09-07-2008, 11:44 AM   #13746
shadow102's Avatar
Trader Rating: 21 (96%+)
10.5?
3.5 /6.5?
thanks
tim
13.5 i am running a 92/50-53
Also depends on your center pulleys being either a 16t or 18t
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 09-07-2008, 01:51 PM   #13747
Default Anti Roll Bar Fitment Questions
Hi every one,
I have never run anti roll bars before and would like to try them. I have the andy moore wce and run 13.5 with lipo. I have fitted the front ARB asper instructions but with the front shocks off if I lift one front wishbone I have to lift it quite alot before the other side lifts. Can you guys tell me how you all set yours up and what adjustments can I make so both front wishbones lift at the same time. Any other tips would be helpfull
RAPID RACER is offline   Reply With Quote
Old 09-07-2008, 05:35 PM   #13748
EJ20's Avatar
Originally Posted by RAPID RACER View Post
Hi every one,
If you using 1.2mm (soft), is normal when you lift one side all the way up, the other side will lift up around less half. If you use the 1.4 (medium), it should lift up a lot more than half. To adjust the sway bar, you need to play with the ball end connector, usually the set screw is straight down to tight it, try to move around or tighten the set screw from the bottom up, it should make difference. Check this out, Hara will show you how. http://www.google.com/translate?u=ht...F8&sl=ja&tl=en
EJ20 is offline   Reply With Quote
Old 09-07-2008, 05:54 PM   #13749
EJ20's Avatar
I have a question about the shocks adjustment. I'm using wce shock tower and when I try to adjust the rear droop from 6 to 5, the spring is not touch the spring tension collar, is that a matter or I need to adjust the length of the shocks? I has 1.5mm roll center, shocks on the tower #2 hole.
Old 09-07-2008, 05:59 PM   #13750
KHoff7's Avatar
When is the TC going to be available again!? The first week of September is gone and I can still not find it anywhere in the Us.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-07-2008, 10:27 PM   #13751
STLNLST's Avatar
Trader Rating: 21 (100%+)
10.5?
3.5 /6.5?
thanks
tim
13.5 I run 4.7-4.5 FDR
10.5 I run 5.2 FDR
3.5 I run 9.4 FDR (13mm rotor)
I've never used a 6.5
This is will Novak motors.
STLNLST is offline   Reply With Quote
Old 09-08-2008, 12:37 AM   #13752
Aid1970's Avatar
Anyone ???
Old 09-08-2008, 12:45 AM   #13753
Korey Harbke's Avatar
The TC has new revised suspension arms with more tuning options, and the new rear diff is a MAJOR improvement over the previous version. The idea of the TC kit is to bring a revised car to market, at a lower cost than the previous. Things on the AME that were just "bling" were left out, and newer revised parts were put around the car to make it better on the track.
All in all I think it's a better performer. But you could have some of the very same benefits of the tc kit by changing to the new suspension arms and the new rear pro spec diff. There are a few other smaller changes around the car, but those two things seem to stand out the most to me.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-08-2008, 04:49 AM   #13754
Aid1970's Avatar
Thanks Korey.
Old 09-08-2008, 11:46 AM   #13755
cyclone speed's Avatar
Hi every one,
from what i have understood from RAPID RACER is that when you lift you car at its centerline both wheels dont lift at the same time with equal droop left right so you have to have some difference in droop left right for both wheel to lift at the same time. if im right i have the same probleme so im also looking for a solution.
and from EJ20 i have the same probleme one touches the tension collar alot and the other one does not touche it at all.
Thanks in advance
cyclone speed is offline   Reply With Quote
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
