Old 08-30-2008, 10:35 AM   #13696
cyclone speed's Avatar
[QUOTE=STLNLST;4788993]
Originally Posted by cyclone speed View Post
To pick up a little more on power steering you could always lay your front shocks down. This will help some but from what you're describing I would work on entering the the "C" corner a little better. If you're pushing to the point to where you hit the wall then you're on the throtle too long. How are other driver's entering that same part of the track? Do they go full punched or do they slow down some? I would think that 5mm of droop is on the gauge but you never know what they are going off of. Sometimes they will state on their set up sheet if droop is measured over ride height.
hi i think that they do slow down but it doesnt look like they slow down . but i will ask them.last question how much over ride height will it give me with 5mm droop on the gauge.
Thank you alot for you help i appriciate your help
cyclone speed is offline   Reply With Quote
Old 08-30-2008, 10:44 AM   #13697
STLNLST's Avatar
Trader Rating: 21 (100%+)
[QUOTE=cyclone speed;4789193]
It's hard to say what it will give you over ride height. It really comes down to the tire's you run. Sorex tire's are taller than Jaco's and RP's Once you set the droop using the gauges....put your tire's on and then measure what it is over ride height.
STLNLST is offline   Reply With Quote
Old 08-30-2008, 10:48 AM   #13698
shadow102's Avatar
Trader Rating: 21 (96%+)
[QUOTE=STLNLST;4789214]
ok guess my question is how you measure the droop over ride height?
Hot Bodies Cyclone - - TeamTekin - - Spektrum - - Team Orion - - Futaba
www.nexusracing.com
www.go-rc.org
shadow102 is offline   Reply With Quote
Old 08-30-2008, 11:19 AM   #13699
[QUOTE=shadow102;4789223]
me , i take a ruler put the car on the setup board or flat surface , mesure the ride height with the ruler, i.e it shows 5mm ride height . Then you lift the car from its centerline ( in the midle of the shock tower, or anywear but from the midle of the car ) until both wheel just lift from the ground , then you look at your ruler and if it shows 8mm it means you have 3 mm droop over ride height.
Basically you do the steps above ( put the car on flat ground , mesure ride height , lift cat at centerline.....) and then you look at the number that is shown on the ruler when the wheels just lift from the ground , and what you do is this :
final number that is shown on the ruler when wheels just lift minest your ride height , this will give you the droop over ride height.
i.e if you have :
5mm ride height and 7mm as final number ( when the wheels just lift)you do : 7-5=2 you have 2 mm of over ride height
4.5 ride height and 8 mm as final number : 8-4.5=3.5 you have 3.5 mm droop over ride height
Hope that helps
Old 08-30-2008, 11:42 AM   #13700
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by lotus1 View Post
One more Q...Might seem dumb but.....Are the MIP's really that much better than the original CVD's? Thanks,Mario.
yes the world's CVD's are way better, lighter, more effecient, more lock to lock steering but barely. But the bestof all they look so much nicer
SammyZ is offline   Reply With Quote
Old 08-30-2008, 01:30 PM   #13701
Thanks.Guess I'll order the set.Big one tho....is the worlds chassis any different than the original one? Mario.
lotus1 is offline   Reply With Quote
Old 08-30-2008, 02:16 PM   #13702
STLNLST's Avatar
If you take a look at Cyclone speed's post I do mine exactly the same except I use my ride height gauge rather than a ruler.
Old 08-30-2008, 11:45 PM   #13703
hi guys , could any of you tell me the weight of you cyclone WCE , 5cell mod .
Because the minimum weight at my local track for running mod , 5cell is 1450 gramms and my car weighs 1507 gramm . and i would like to lower the weight down to around 1460 ,is this possible ,if yes could you tell me
Thank you
Old 08-31-2008, 02:32 AM   #13704
SammyZ's Avatar
Thank you
wow...i can't believe peopel actually obey weight limits I guess im the only cheater i think when i was runnign 6 cell WCE i clocked in at about 1215grams!
Anyways the WCE chassis is the same as the Hara/Surikarn/Black chassis. But is only slightly diffrent than the new TC chassis. There is no advantage of 1 chassis to another.
Old 08-31-2008, 07:15 AM   #13705
mangoman's Avatar
Thank you
I had my car at 1450, that was with low profile servo, micro spektrum receiver and RS/R1 esc. I had aluminium universals in the rear, but HD steel unis up front.
Also no heat sink/fan on the motor.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 08-31-2008, 08:37 AM   #13706
Stew Noble's Avatar
Thank you
1450g, thats an unusual weight......you live in the UK right? The minimum weight is usually 1425g......I've only been able to get below this with the TC kit though.....
// S N F //
Stew Noble is offline   Reply With Quote
Old 08-31-2008, 12:30 PM   #13707
yeah i live in the UK but i would like to achieve a lower weight without buying any more esc , motor , low profile servo . i might get a low profile servo but beetween the low profile and the normal servo theres no weight differente . i would like to get a lower weight without buying anything more . My electrinic are GTB , LRP bl 5.5 5cell micro receiver and normal servo . if its not possible , tell me but i would like to lower the wieght by triming , shaving anything possibl thanks
Old 08-31-2008, 03:20 PM   #13708
shadow102's Avatar
Anybody do any testing with the r9-r on the cyclone yet? I need a new body and was thinking of picking up this body or just going with the tried and true mazda6
www.nexusracing.com
www.go-rc.org
Old 08-31-2008, 06:13 PM   #13709
RC MARKET's Avatar
Use Speed 6 only !
RC MARKET is offline   Reply With Quote
Old 08-31-2008, 06:20 PM   #13710
shadow102's Avatar
thats what i was thinking but just wanted to make sure since the R9-R is a new on the market and so far i have heard nothing but good things about it
www.nexusracing.com
www.go-rc.org
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
