Old 08-27-2008, 10:56 AM   #13651
RC MARKET's Avatar
Originally Posted by pcar951 View Post
OK guys. WCE chassis on a tight, low traction carpet track - rubber tire, 13.5and 10.5 lipo. My question is; spool, 1 way or diff in front??
1ST point use 28-32R with Orion JB Foam insert !
RC MARKET is offline   Reply With Quote
Old 08-27-2008, 03:10 PM   #13652
TheCoolCanFanMan's Avatar
Originally Posted by Korey Harbke View Post
Not yet buddy, I'm waiting for you guys to get them back in stock . I need to get those anyway to build up a foam tire carpet car.
Clint- The outdrives wear freakin awesome!!!!
-Korey
What outdrives are they Korey
And what is your setup with the Hara springs please. Is it for rubber tyers as well as for outside?
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-27-2008, 03:39 PM   #13653
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
any one have a TC, WCE OR Blue cyclone for sale?
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 08-27-2008, 03:50 PM   #13654
STLNLST's Avatar
Trader Rating: 17 (100%+)
Cheers Malc
If you need a great asphalt set up go to www.gearchart.com and look at Scotty Barnes Reedy warm up set up. It's awesome and works on high bite and med bite outdoor tracks. The out drivers Korey is talking about are the stock one's that come with the pro-spec diff.
STLNLST is offline   Reply With Quote
Old 08-27-2008, 04:35 PM   #13655
cyclone x's Avatar
hey does anybody know how tight the diff should be.
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 08-27-2008, 05:18 PM   #13656
I ment for the TC
Cheers Malc
Old 08-27-2008, 05:28 PM   #13657
To me you should, while holding the left rear wheel and spur, try and crank over the right rear wheel, and if you can't then your about right, but if you can, keep tightening the diff screw until you cant crank the rear left wheel and should be about there. but the diff needs to be run in for about 30 secs then checked, or it may start to slip, and should be a smooth action
Malc
Old 08-27-2008, 10:27 PM   #13658
pcar951's Avatar
Trader Rating: 19 (100%+)
[QUOTE=B18C Turbo;4779601]just like shaun said, spool for high bite track, and if your track uses wood barriers, forget the spool, if you tap them once the car will explode.
Woa! I might try and fab up a slipper spool.
pcar951 is offline   Reply With Quote
Old 08-28-2008, 12:09 AM   #13659
SammyZ's Avatar
Trader Rating: 138 (100%+)
sent ya a pm!
SammyZ is offline   Reply With Quote
Old 08-28-2008, 05:06 AM   #13660
cyclone speed's Avatar
hi guys,
i just want to say 2 things:
first : thanks to all of you that has helped me to setup my car because i went to practice today and is was great i just had understeer probleme but appart this all your help has been great .
seconde : as i said i had understeer probleme , and i was wondering if any of you could just tell me what could i do to decrease the understeer probleme .
Ive been told that by increasing droop will help but i just wanted your opinion.
thanks again
cyclone speed is offline   Reply With Quote
Old 08-28-2008, 09:04 AM   #13661
STLNLST's Avatar
Originally Posted by cyclone speed View Post
hi guys,
thanks again
droop should be the easiest and quickest change. Your best bet would be to play with the droop in the rear first. How do you measure your droop and what is it at front and rear currently???
Old 08-28-2008, 09:37 AM   #13662
my current droop is 3mm rear and 2.5 front and just to say i had a spool
Old 08-28-2008, 10:15 AM   #13663
STLNLST's Avatar
Try going to 3.5 or 4 in the rear. That will allow more weight to transfer to the front when you let off power giving you a little more steering. I tried this last weekend and it helped the car out a bunch. I started the day with 6mm up front and 6mm in the rear.....once I went to 5mm in the rear the car got better. I bet if I went to 4.5 it would have been 100% perfect rather than 98% I hope this helps you out some. I found that changing droop had a better and quicker effect on the car instead on changing shock positions or camber change. Good luck!!!
Old 08-28-2008, 10:56 AM   #13664
il try this and let you know . im sory i said 2.5 front and 3mm rear but i had 3mm front and 3mm rear sorry for the mistake . so should i keep 3mm in front ?
thanks for the quick replys
Old 08-28-2008, 11:52 AM   #13665
RC MARKET's Avatar
5-6 Cell Cyclone TC Main Chassis back in stock now !
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 08:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 08:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 08:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 03:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 06:15 AM
SEO by vBSEO 3.5.0
