Old 10-07-2005, 08:09 AM   #1351
rc-zombies's Avatar
Originally Posted by S-T-R-l-K-E-R
any hop-ups needed?
no hop-up needed.... other than additional purple bling-bling..
if you don't have a pro4 already...then you'll need the Pro4 spring set.
comes with the complete sway bars set already.
other tuning options: front spool when they become available.
Old 10-07-2005, 08:26 AM   #1352
Skill's Avatar
Picked up my Cyclone today, will be building tonight and tomorrow to get it ready for racing tomorrow night so I will let everyone know how it goes!
Skill is offline   Reply With Quote
Old 10-07-2005, 08:30 AM   #1353
rc-zombies's Avatar
now you can change your sig to Cyclone is here
should take less than 4 hrs to build at a leisurely pace. not including chassis prep.
Old 10-07-2005, 09:59 AM   #1354
Anybody know where I can find a manual to check out before I shell my cash?
Asurada Sugo is offline   Reply With Quote
Old 10-07-2005, 10:25 AM   #1355
BerNardLee's Avatar
Originally Posted by rc-zombies
I already built another diff and
I found that building the diff with 2 bearings was smoother than the what the manual says to do with spacer/bearing/spacer set-up.
Hi Zombies,
Do you mind to elaborate in more details about building diff with two bearings.
BerNardLee is offline   Reply With Quote
Old 10-07-2005, 10:41 AM   #1356
rc-zombies's Avatar
Originally Posted by BerNardLee
Hi Zombies,
on the pro4 the diff is built with 2 bearing inside the diff gear.
see page 14 of the Hara Pro4 manual. can be downloaded from
the Europe hpi website.
http://www.hpieurope.com/instruction...=en&partNo=187
on the cyclone it has only 1 bearing between 2 spacers. when you stack them up they are not equal to 2 bearing. and part of the diff support extends out.
Old 10-07-2005, 10:42 AM   #1357
rc-zombies's Avatar
haven't seen the manual posted anywhere yet..
after several packs of test runs.. I have to say the car is very impressive..more so than my Hara Pro4. Car carries alot of corner speed, lots of steering.
If you guys need a base asphalt/rubber tire set up try Hara's base set-up found on the HPI Japan site..it's right on the money.
http://www.hpiracing.co.jp/contents/.../download.html
Old 10-07-2005, 10:33 PM   #1358
ogreasurada's Avatar
Could anyone tell me if Cyclone uses the same suspension parts (arms and hubs) as Pro4? thx.
ogreasurada is offline   Reply With Quote
Old 10-07-2005, 10:53 PM   #1359
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
which one in specific? there are lots here.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 10-08-2005, 12:00 AM   #1360
Skill's Avatar
Yes, it uses Pro 4 wishbones, rear hubs, c-hubs, steering knuckles, toe blocks, and a few other minor bits and pieces.
I got most of the build done last night, the quality of the parts is impressive, and it is a very easy build, but I also noticed as many other people have that the rear diff has a lot of play in the pulley, has anyone found a fix to this yet? I did use 2 bearings instead of the bearing and 2 spacers as Zombies suggested, and I also tried a few other combinations and nothing got rid of the play. Having said that, it doesn't seem to make any difference to the performance of the diff, it seems nice and smooth and tight too.
Another issue I had, after looking at the instructions a few times, and the ammendment sheet in the manual (yes, I got one in mine!) was that the one-way pulley seems to rub slightly on the spur gear plate, or more specifically the screws. I'm not sure whether it's because I used my titanium screws on it or not, but all the other screws are flush to the carbon fibre and these ones seem to stick out a bit. Has anyone else had this issue?
So far I am quite impressed by the build quality of the kit, but the drivetrain doesn't seem very free, but maybe that's just because I'm used to the freeness of the Pro 4
Old 10-08-2005, 01:16 AM   #1361
V12
V12's Avatar
Usually a brandnew belt drivetrain needs some runs to be broken in. Then itīs much more free than before.
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 10-08-2005, 05:29 AM   #1362
Recieved my Ti Racing spool and driveshafts today. The quality is great and the drive shafts are far lighter than the stock ones. If anyone is thinking about buting them then they get my vote.
Rick Draper is offline   Reply With Quote
Old 10-08-2005, 07:31 AM   #1363
does anyone know where i can get those racing spools over here (usa)?
Old 10-08-2005, 10:40 AM   #1364
rc-zombies's Avatar
bottom new one...the one that says cycone.
Old 10-08-2005, 11:29 PM   #1365
thanks man. btw what pivot blocks come with the kit (both front and rear)
Hot Bodies Cyclone S wardyl Electric On-Road 4 10-01-2008 07:01 AM
Hot bodies Cyclone 12 k7king R/C Items: For Sale/Trade 1 09-04-2008 07:09 AM
WTB Hot Bodies Cyclone/ cyclone Parts tenpins77 R/C Items: Wanted to Buy 0 07-29-2008 07:48 AM
Hot Bodies Cyclone sdt1 Australia For Sale/Trade 6 07-13-2008 02:05 AM
WTB: Cyclone S/Cyclone Painted bodies vazzo Australia Wanted to Buy 0 02-05-2008 05:15 AM
